IFD 440 not saving config settings in maintenance |
ChainSaw
Groupie Joined: 28 May 2018 Location: CA Status: Offline Points: 47 |
Posted: 26 May 2020 at 3:59am |
Not sure if this is a configuration PIN# problem or
Not. I went into maintenance mode using the "update database" LSK From "AUX" (i.e. without using a USB at boot and no USB Connected at all). I went to Config. Entered the PIN#. Then, I twisted the lower right Outer knob to get to the lighting config page. I changed settings on that page But when I went to another config page, then back to the lighting page, my changes were not saved. I repeated this several times to verify the behavior. I also noticed the same problem when I changed Parameters on other configuration pages. I even attempted going directly from changing the desired parameter in config to exiting maintenance mode. Nothing I tried would save the changed parameters when I went back into maintenance mode to check. How do I make the ifd440 retain parameters that I change in maintenance mode? Thank you. Edited by ChainSaw - 26 May 2020 at 4:02am |
The settings are saved as soon as you change them. As you say, though, if the PIN isn't correct then they don't get saved. If a PIN is required and has not been entered correctly, the top of the pages will say "Password Protected".
ChainSaw
After I entered the pin, the yellow 'password protected' message went away, but still did not save my settings. Is there any other indication that the password has been accepted? How do I disable the password?
Better call tech support for that one, then, because after you've successfully entered the PIN, the settings should save. Once you've entered a PIN, you can't get rid of it yourself. But, tech support can send you a DSF that will do it.
