  New Posts New Posts RSS Feed - IFD 440 not saving config settings in maintenance
ChainSaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Topic: IFD 440 not saving config settings in maintenance
    Posted: 26 May 2020 at 3:59am
Not sure if this is a configuration PIN# problem or
Not.
I went into maintenance mode using the "update database" LSK
From "AUX" (i.e. without using a USB at boot and no USB
Connected at all).
I went to Config. Entered the PIN#. Then, I twisted the lower right
Outer knob to get to the lighting config page. I changed settings on that page
But when I went to another config page, then back to
the lighting page, my changes were not saved. I repeated this several times
to verify the behavior. I also noticed the same problem when I changed
Parameters on other configuration pages. I even attempted going directly from changing the desired parameter in config to exiting maintenance mode. Nothing I tried would save the changed parameters when I went back into maintenance mode to check.
How do I make the ifd440 retain parameters that I change in maintenance mode?
Thank you.
Edited by ChainSaw - 26 May 2020 at 4:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 8:32am
The settings are saved as soon as you change them.  As you say, though, if the PIN isn't correct then they don't get saved.  If a PIN is required and has not been entered correctly, the top of the pages will say "Password Protected".
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 9:44am
After I entered the pin, the yellow 'password protected' message went away, but still did not save my settings. Is there any other indication that the password has been accepted? How do I disable the password?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2020 at 10:36am
Better call tech support for that one, then, because after you've successfully entered the PIN, the settings should save.  Once you've entered a PIN, you can't get rid of it yourself.  But, tech support can send you a DSF that will do it.
