  New Posts New Posts RSS Feed - IFD100 Squawks
IFD100 Squawks
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Topic: IFD100 Squawks
    Posted: 14 May 2020 at 9:56am
Using the latest versions of IFD100 & IFD540's (dual), I am noticing some minor squawks.
I think the first is old...
1.  Local Time showed 3 AM when it was really 8+ AM.   Zulu Time works fine.
2.  Pulling ADSB Wx from MLB100 (dba Skytrax100) via IFD540, the
only Wind Altitude showing is FL03.0.  All Wind FL's ok on IFD540's, but on IFD100, seems to be locked on 3000'.  So, I don't display WINDS anymore on the IFD100.  All other Wx functions OK (Sigmets, Metars. Conus, etc).
Anybody else having this??
Tom W.
afassas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote afassas Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 9:29am
I concur that the IFD-100 app does not handle UTC offset settings correctly.
I have not taken at look at ADSB wind data from the IFD-100, so no comment there.
Alex Fassas
Avidyne IFD-540
Lynx NGT-9000+
Beech A36
KRGA
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2021 at 3:53pm
In recent flights, I am using the IFD100 more than FF, but still surprised Avi-Tech Support has neither commented nor fixed the "Designated Waypoint" Squawk:
. Works great on the panel IFD's
. On IFD100, this datablock shows the chosen block from the panel only.
IOW, on the IFD100, this Designated Waypoint block does NOT ACtivate or allow a choice to be made.
To bad, as this is one of the most useful datablocks available.
Whats up with this?
Tom W.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 9:21am
We know about the problem and it will be fixed in the IFD100 release corresponding to 10.3
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2021 at 11:57am
Thank you Steve.
Response appreciated, and we look forward to the v10.3 fix.
Tom W.
D-EACY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-EACY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2021 at 4:49pm
On my last flight the IFD100 did not sync completely with the IFD440 ...
The frequencies of the IFD440 all showed up, but no route, not in the FMS and not on the map Actually it did show up first but disappeared later!
Latest iOS (14.7) on iPad mini (5), latest database on both the IFD and in IFD100.
2006 SR22-G2 DFC90 IFD440
