IFD 440 Network Config Questions |
Post Reply |
Author | |
neckdr
Newbie Joined: 23 Jan 2020 Location: Florida Status: Offline Points: 2 |
Post Options
Thanks(0)
Posted: 02 Mar 2020 at 5:55am |
I am trying to set up the IFD440 as a client to my Stratus so that I can see traffic and weather from Stratus on the IFD100 app along with the NavData and still have radios on the IFD100 app. I have the Jeppeson $299 Nav Data subscription.
So far, this is what I have tried as per the Avidyne Pilot Guide: Defined WIFI Configurations: Pg. 6-70: In Maintenance mode: Set up "Stratus" as a Remote WiFi and also have the IFD440 set up as a Local WiFi Selecting Network Configuration: Pg. 6-73: Started the IFD440 in flight mode. Went to the AUX page, SETUP tab, and selected the Stratus as the desired SSID/Name. On my Ipad, in settings selected Stratus for WiFi. With this, I was able to see traffic on Foreflight but there was no traffic and no radio information on the IFD100. Radio from the IFD440 in the panel was not being transmitted to the IFD100. I tried setting the IFD440 (Local WiFi) as the desired SSID/Name with selecting IFD440 as the WiFi on the Ipad. This gave me the radio information on the IFD100 and the NavData, but still no traffic or weather. Is there a way to set up this system which will allow the IFD440 to have all of its function on the IFD100 and include the traffic and weather from Stratus? |
LarryH
Newbie Joined: 17 Mar 2020 Location: Kirkland, washi Status: Offline Points: 12 |
Post Options
Thanks(0)
From your description, you are not using the full SSID for the Stratus. Check the WiFi connection on your IPad for the correct SSID. You can also look on the bottom of the Stratus for your SSID. The SSID will be similar to Stratus012345, where the numbers are the serial number for your unit.
Note too that both the SSID and the password (if used) are case sensitive.
TXCARGY
Newbie Joined: 30 Nov 2019 Location: DFW Status: Offline Points: 12 |
Post Options
Thanks(0)
If set up this way do I understand correctly that I would be able to get traffic on my IFD100 from my Stratus? I use Foreflight on a separate IPad.
Victor
Bellanca 17-31ATC www.bellanca.us |
AZ Flyer
Senior Member Joined: 12 Feb 2018 Location: Tucson, AZ Status: Offline Points: 164 |
Post Options
Thanks(0)
Setting a password on the Stratus can cause problems. I don't recall what the issue is.
Stan
LarryH
Post Options
Thanks(0)
You will not see traffic on the IFD100 as the traffic has to be sent from the IFD440. The Stratus is not certified for traffic/weather input to the IFD440 but you will see traffic and weather in Foreflight. All other interface data between the IFD440 and the IFD100 will be shared. You can also send and receive flight plans in Foreflight between the IFD440.
LarryH
Post Options
Thanks(0)
I have been using a password on my Stratus2s from the get go. No issues. Actually by doing so, the IPad will stay connected rather than trying to switch WiFi open networks while on the ground or low to the ground.
Also, make sure Cellular Data is turned off on all devices aboard the aircraft or in airplane mode for devices you are not using for flight. This helps by eliminating possible interference.
AviSteve
Admin Group Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2236 |
Post Options
Thanks(0)
You can get ADS-B Traffic and Weather from the Stratus onto the most recent version of the IFD100 app. It only works with the Stratus 3, though. You'll have to go to the IFD100 settings on the iPad to enable it.
Avidyne Engineering |
TXCARGY
Post Options
Thanks(0)
Thanks for that information Steve
Victor
pburger
Senior Member Joined: 26 Dec 2013 Location: United States Status: Offline Points: 406 |
Post Options
Thanks(0)
Say what?? When did this happen? Only with Stratus 3? What about Stratux? Sounds like something to mess with on a rainy day. (he said as he went into the other room to get his iPad, as the rain continued to fall outside)
pburger
Post Options
Thanks(0)
Are you saying that the IFD-100 app can display traffic that originates from the Stratus3? Or just that traffic from the IFD-540 (440) can pass thru to the IFD-100 on the Stratus3 WIFI network? Edited by pburger - 22 Mar 2020 at 9:05am |
brou0040
Senior Member Joined: 13 Dec 2012 Location: KIYK Status: Offline Points: 720 |
Post Options
Thanks(0)
I swear I've seen traffic on the IFD100 and I don't have traffic on my IFD540, must have come from my stratux. Either that or it's been too long since I've gone flying.
Edited by brou0040 - 22 Mar 2020 at 6:00pm |
AviSteve
Post Options
Thanks(0)
Yes, with the latest version.
chflyer
Senior Member Joined: 24 Jan 2013 Location: LSZK Status: Offline Points: 1034 |
Post Options
Thanks(0)
So traffic from the Stratus3 over wifi will display on the IFD100 but not on the IFD540, correct?
AviSteve
Post Options
Thanks(0)
Correct
pburger
Post Options
Thanks(0)
How specifically do you set that up? I didn't see any settings to turn traffic on or off. I know you said it was only on the Stratus3, so can you say it definitely won't work with Stratux? or is there a chance that it might work? |
AviSteve
Post Options
Thanks(0)
The IFD100 Settings has an option for "WIFI ADS-B Support". Turn that on. I don't know whether it works with a Stratux. When you find out, post back to let us all know.
TXCARGY
Post Options
Thanks(0)
I can not find the option in settings fo WIFI ADS-B support. I have version 10.2.4 and ISO 12.4.5 on my IPad. Do I have the correct version of the IFD100? If not where do I get it?
Edited by TXCARGY - 24 Mar 2020 at 12:18pm |
Victor
AviSteve
Post Options
Thanks(0)
IFD100 version is 10.2.8 and it's available on the app store.
TXCARGY
Post Options
Thanks(0)
Steve
Thanks for the quick response. I go to the Apple app store and it shows that I have the current version and there is no update available.
Victor
chflyer
Post Options
Thanks(0)
You certainly have the option, but you won't find it in the app itself. You need to find the app under the ipad Settings app after all the other system settings. It's in there where you also set which model IFD and unit numbers.
Edited by chflyer - 24 Mar 2020 at 1:32pm |
ddgates
Post Options
Thanks(0)
The ADS-B Support button is in Settings, not in the app per se.
Edited by ddgates - 24 Mar 2020 at 1:32pm |
TXCARGY
Post Options
Thanks(0)
Thanks for the information. Now I have got it. I was trying to do it thru the app.
Victor
pburger
Post Options
Thanks(0)
Ahhh... In iPad settings. I'll check that out tonight and report back.
teeth6
Senior Member Joined: 10 Mar 2014 Status: Offline Points: 741 |
Post Options
Thanks(0)
I talked with a Avidyne and FF about this but am wondering if anyone else experiences this.
Edited by teeth6 - 25 Mar 2020 at 10:55am |
teeth6
Post Options
Thanks(0)
As no one responded to the above, it seems I'm the only one experiencing this. FF points to Avidyne to make a fix but Avidyne says FF must make a change. In reality, it seems no one has this issue. Would someone do a quick test for me when they next fly if they use their IFD as the WiFi source and use both FF and the IFD 100. When using FF with the IFD running in the background, I do not get traffic or some weather products on FF. With the IFD in the background, on the device page of FF, I see ONLY the Avidyne IFD connected (provides GPS and flight plan transfers). I don't have an option on the map page to even see traffic. Once I quit out of the IFD 100, the FF device page then shows the same Avidyne IFD but also an ADS-b connected (provides GPS and ADS-B). Without the ADS-B (when the IFD100 is running) perhaps that's why I get no traffic or some weather on FF. Only guessing but I'd love to solve this riddle. The top left pix is the device page when the IFD is running in the background and the top right pix is when the IFD100 app is quit out of. The circled settings on the map page are not even an available choice when I have the IFD100 running in the background. IF someone could confirm they are able to get these option in FF even with the IFD 100 running (when using the IFD 540/440 as the WiFi source), then I know it is something peculiar to my set up only.
LarryH
Post Options
Thanks(0)
it has been my understanding both an IPad with FF and another with the IFD100 will work on the IFD WiFi together from either reading an article or seeing a video. I have yet to try it though as I do not have two IPads. I do remember there are settings that have to be made for both to work.
teeth6
Post Options
Thanks(0)
Thanks but I'm speaking of using just ONE IPad. I used to be able to use FF and the IFD 100 on the same IPad with one running in the background when the other app was the active one. Somewhere along the way, FF stopped showing traffic and some weather products if the IFD 100 was running in the background and I'm trying to find out if it is just me.
AviSteve
Post Options
Thanks(0)
We've tried your setup here and it works for us. Our iPad is on iOS13. If you're on an older version, you could try updating your iPad.
Also, set the "WiFi Open ADSB support" in the IFD100 App settings to "Off". It shouldn't actually make a difference for this problem, but might be worth a try.
teeth6
Post Options
Thanks(0)
Ugh...looks like I'm the problem child again. I am on IOS 13.4 and I do have that ADSB support set to off. When you have the IFD 100 in the background, do you still see both of the FF device icons in my picture on the right?
AviSteve
Post Options
Thanks(0)
Sorry, don't remember. My colleague will have to try it again next time he's in the office, but not sure when that will be. We'll let you know.
teeth6
Post Options
Thanks(0)
Thank you
LarryH
Post Options
Thanks(0)
Question. Doesn’t the version of the IFD100 have to be the same as the IFD?
I just noticed my IFD100 is v10.2.4.1. My IFD550/540 are at 10.2.3.1.
teeth6
Post Options
Thanks(0)
No. You have the latest version of the IFD 100 and have not yet updated the panel mount to the interim release that came out last month. 10.2.4.1 is available for the panel mount but it was a very minor upgrade and not required to work with the IFD 100
Post Reply | |
Tweet
