IFD540, IFD510 and IFD440 FAQs |
Post Reply | Page 12> |
Posted: 03 Jan 2012 at 5:19pm |
Just uploaded an updated set of IFD540 and IFD510 FAQs as of 3 January 2012. They can be found at:
http://www.avidyne.com/downloads/products/ifd540/IFD540-FAQ.pdf |
IFD510 and IFD540 FAQs just updated again as of 25 Jan 2012. Location is unchanged.
Heads up - I'll be posting an updated set of FAQs in a few days and will make a new post when they are available. Are there any additional topics anyone wants to see in that updated set?
How will the DFC90 GPSS mode be activated when combined with the Aspen PFD? On the 55x with the aspen, the 55x GPSS activation mode (push nav button twice) is disabled and instead activated with the LSK from the Aspen PFD. Hopefully the DFC90 retains the GPSS switch active and the Aspen GPSS LSK goes away. This allows the autopilot modes to be controlled from one device rather than two.
Updated set of FAQs were just posted today (5 July) that include some updates for IFD540 material and then adds all the new IFD440 material.
http://www.avidyne.com/downloads/products/ifd540/IFD540-FAQ.pdf (Gring - will post an answer when I return next week - just want to double check one fact first on the Aspen GPSS behavior.) |
Updated set of IFD540/510/440 FAQs posted today that include updates to 10ish entries. All updates were date tagged 31 Mar 2013.
bellanca1730a
Groupie Joined: 04 Jul 2013 Location: Tampa Status: Offline Points: 63 |
I note from the current FAQs that the Comant CI-2580-200 is listed, but comments indicate WAAS Gamma 1 only. However, per Cobham's website, at least the new CI-2580-200s do, in fact, meet WAAS Gamma 3 specs. Is this easily addressed?
See http://www.cobham.com/about-cobham/aerospace-and-security/about-us/antenna-systems/communication-and-navigation-antennas-and-products/products-and-services/general-aviation-antennas/comdat-multi-function-antennas/comant-ci-2580-200-datasheet.aspx. |
Sean Andrews
Bellanca Super Viking |
Good question. I'll check.
bellanca1730a
I know you are busy, but curious if you were able to get an answer. Thanks.
Sean Andrews
Good catch. I've put it on the to-do list for early next week. Sorry about dropping that ball.
We agree that (at least the new) CI 2580-200 do support Gamma 3 so they are full-up WAAS antennas and will be included in the initial release of the IFD540.
bellanca1730a
Great. Thanks.
Sean Andrews
Updated FAQs posted today. They can still be accessed at:
phkmn
Groupie Joined: 06 Feb 2013 Location: Chicago Status: Offline Points: 78 |
Your "compatible equipment list" includes the Garmin 330 and the 330 ES.
Am I correctly understanding that my Garmin 330 will display TIS traffic on the IFD540? I'm puzzled by the inclusion of the 330ES, based on a statement elsewhere on the forum that it is doubtful that the ES will be able use the 540 as a GPS position source, given Garmin's unwillingness to share the protocol. The new axp340 Avidyne transponder is supposed to be ES compatible with the IFD540, but that unit is built by Trig, right? Trig's TT31 ES transponder can use the GNS530 as ADSB out source, so somebody must know what the protocol is. |
PH
You will see TIS (ModeS) traffic on your 540 (or 530 or ASPEN etc.), with either a 330 or 330ES. That signal is open protocol.
And yes, you will NOT get ADS-B compliance with a 540 + 330ES, because the WAAS position signal that the 330ES expects to see is closed, and Garmin has so far refused to release the specs. If you want to be ADS-B compliant with a Garmin 330ES, you have to use a Garmin GPS as the WAAS position source. That should clearly be noted in the compatibility list, if it isn't. It appears the 530 may also provide an open protocol GPS WAAS source data, but the 330ES will not use it. NOT AN OFFICIAL response, just from my musings. * Orest Edited by oskrypuch - 16 Jan 2014 at 9:00am |
I think the same (or actually reverse) is true of the Avidyne transponder; if I understand Steve correctly, it will use the Avidyne 540 for a WAAS ADS-B position source, but not the Garmin units.
Is that what everybody understands? Is it the case that the AXP will not use the Garmin units, or rather, Avidyne does not know if it will or will not?
Orest is correct and David is as well.
I think we can safely assume the Garmin units are not going to magically start sending non-proprietary ADS-B compliant GPS data for units like the AXP340 to use. That would be a major corporate reversal for them. We'd be thrilled if it happens but I'm not holding my breath. |
phkmn
Since I have a GTX330, this creates a problem for me if I want to have ADS-B out. I will either have to cancel my IFD540 order or buy Avidyne's transponder and try to sell my 330 in addition to my 530.
Avidyne could help with this by offering a trade-in program for non-compatible transponders. |
PH
glassanza
Groupie Joined: 26 Feb 2013 Location: Georgia Status: Offline Points: 98 |
Thread from IFD 540 data upload time &ship's power issue
I too have a GTX 330 and have beat this horse to death... I prepurchased a pretty expensive AXP340 based on what appears to be changing information. Last week cancelled my order based on more recent information from this forum and now think I need to repurchase the cancelled 340.... I realize most of you posting questions here are way smarter than I am with regard to past and present avionics. That being said, I'm just trying to buy the most compatible equipment now so I don't have to tear my airplane apart again in 3 years. I know things are changing rapidly but please, if I can't get enough information here to figure out if I should buy a new transponder or wait or just upgrade what I currently have then how do you expect to sell the next wave of GA pilots forced to upgrade by the 2020 deadline? This has been a frustrating process to say the least.
GDC25
heldjp
Newbie Joined: 10 Sep 2012 Status: Offline Points: 2 |
I am in the same boat! I have had a 330ES for quite a few years and never dreamed it would not work with the IFD540! As you say, I hope Avidyne comes up with some sort of discount for the pre-buyers needing the AXP340, with another $6000 + installation for the APX I might have to reconsider this purchase.
JP |
KIM
What's about the Trig TT31? Is it fully compatible? |
Klaus
Not sure if you guys saw the other thread on AXP340 Revised pricing but as of 17 Jan 2014, the AXP340 list price is now $3,995.
As for the TT31 compatibility question, I'm not exactly sure if you're asking if it is fully compatible with the IFD540 (it is), or something else. I fly every day with the IFD540 - AXP340 combo. We have another airplane in our test fleet that flies with the IFD540 - TT31 combo.
phkmn
Many thanks for the price update: that is very good news.
PH
It changes everything!
phkmn
OK, so now I need an ADS-B receiver.
Aspen has an ARX100 dual band unit. Will that display on the IFD540, or only on the Aspen PFD? I want a panel receiver: don't want to have to look down at an Ipad for traffic. |
PH
I don't know anything about the ARX100.
By "dual band" I'm guessing you mean it can capture and send ADS-B supplied weather data to a display. If so, then I'm also guessing that only displays in the Aspen glass but I do know that the IFD540 definitely will not display that data at initial release.
phkmn
The arx100 is just a dual band receiver. I would then rely on the AXP340 for the 1090 out.
Anyway, I need to know what receiver WILL display TIS and FIS on the IFD540. Please give us some guidance here if Avidyne does not have its own receiver. |
PH
bellanca1730a
+1 ... even if such a receiver is still early in the pipeline, it would be helpful just to know "we hope to have a competitive ADS-B re/transceiver certified and available ahead of the 2020 mandate" ... absent that, some guidance regarding the competitive (but compatible) landscape would be the next best thing.
Sean Andrews
Leonard
+2 |
Hi Sean et al,
It is imperative that Avidyne has a full array of product offerings that support all aspects of ADS-B functionality and we will. We have a number of products in the internal pipeline, all of which will be out well before any mandate or rush to equip prior to mandates. We have announced full support for the Capstone protocol - the comm protocol between receivers and displays that allow ADS-B supplied weather and traffic. The initial release of the IFD540 does not have that display code in it yet but will on a subsequent release. When it does, it should in principal take in data from any receiver that is outputting the data in that protocol. The IFD540 has spare I/O that is designed to take that data in and send it out as needed. We have announced our TAS-A traffic products and offer a $2K price guarantee/early buy in option. When the TAS-A products are out, then the ADS-B compliant traffic sensor piece will exist. We are now certified and shipping the AXP340 ADS-B Mode S Transponder. If that transponder is getting ADS-B compliant GPS position from a device like the IFD540, then you have the transponder piece taken care of. We have a number of other not-yet-announced products in the pipeline that will enhance those capabilities, including the ability to organically support 978 and 1090 data streams (i.e. our own receivers). All of these products are, or will be, competitively priced. |
bellanca1730a
Excellent. Thank you, Steve.
Sean Andrews
Slightly revised set of IFD540/440 FAQs just uploaded. Items changed are marked as 10 or 11 March 2014.
Same link as always works: http://www.avidyne.com/downloads/products/ifd540/IFD540-FAQ.pdf |
Edited by MysticCobra - 11 Mar 2014 at 1:42pm |
Strange, I downloaded it about 8hr ago and I find lots….. p.5, 12,13,14, etc, etc
phkmn
I agree. Note that they are not in chronological order. |
PH
Weird. I see it now. Maybe my browser had a cached copy or something.
1964-m20e
Groupie Joined: 19 Aug 2013 Location: New Orleans Status: Offline Points: 69 |
Will the 440 and 540
interface with the TT-21 or T-22 and provide ADSB-out? I
originally had a 540 but opted for the 440 when I was forced to change planes
and i did not want to redo the panel in the new plane. I would really like the
540 over the 440 and my current configuration my GT327 takes up too much room
in the center stack. So I’m looking for options
since the 540 has been taking longer to get certified. |
IFD440 and IFD540 FAQs updated. Changed items are marked as 5 January 2015.
They can be accessed here: http://www.avidyne.com/downloads/products/ifd540/IFD540-FAQ.pdf |
tony
I like the new answers, very interesting....
Thanks for updating the FAQ. It sounds like a bluetooth keyboard could be a good iPad application...
Edited by Gring - 05 Jan 2015 at 3:40pm |
brou0040
Thanks for the update. Could you please update questions 22 and 92 regarding who can perform an update. The two questions use different terms for the facilities that can perform an update, and neither response mentions any shop that holds a repair station certificate, an A&P, or an Experimental Aircraft owner with log book signoff authority.
Getting a little ahead but, can you clarify if there will be limitations to bluetooth keyboard support - will all be supported? What version bluetooth are you using? Do you know of any special keys to consider such as the windows/command/function keys that may be used for shortcuts or commands? I'm thinking I'd get something small like this (http://www.amazon.com/HDE-Bluetooth-Wireless-Keyboard-Smartphones/dp/B00H88HC4Y/ref=sr_1_2?ie=UTF8&qid=1420517429&sr=8-2&keywords=mini+bluetooth+keyboard). I think that could be very useful, at least until the tablet/wifi/540 supports uploading.
I will updated 22 and 92 accordingly later today - thanks for the heads up.
You are getting ahead of yourself on the BT. We tried that keyboard and it's too cheap. The one that we'll supply is the same form factor but of better/higher quality. For at least the initial release, the BT keyboard will just replace the functions of the virtual keyboard on the display. So that basically means numbers and letters only - no function keys or navigation keys supported. |
22 and 92 updated and revised copy uploaded.
Paul
"The one that we'll supply..."
The one you will supply??? Tell us more! |
A late stocking stuffer perhaps! * Orest Edited by oskrypuch - 06 Jan 2015 at 4:20pm |
Royski
UPS tells me I have a package incoming from Avidyne. Printed Pilot Guide, bluetooth keyboard, maybe both?
Avidyne also supplies IFD540s, AXP340s, AMX240s, etc.
I doubt they're going to just be handing out BT keyboards for free.
No bluetooth keyboard for Royski yet but.....we will be distributing free BT keyboards to all IFD540/440 owners when we get the WiFi/Bluetooth STC approval.
They're little beauties. Nice compact form factor but they feel robust (not little flimsy things) and are backlit too. |
Wow, that is awesome! I don't get surprised by much, but this one sure took me by surprise. Good for you!
I am amazed.
I already have a BT keyboard, but I am sure what Avidyne uses will be better. Eager to go forward!
