  New Posts New Posts RSS Feed - Apparently don't turn off your ADS-B signal!
ansond View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ansond Quote  Post ReplyReply Direct Link To This Post Topic: Apparently don't turn off your ADS-B signal!
    Posted: 31 Jan 2020 at 10:45am
FYI, I read this article in AOPA and had the following question - if you accicentially cause your transponder to flip into "stdby" mode, are you still transmitting your ADS-B signal?
If not, this would seem to be a super easy way to get into serious trouble rapidly with the FAA now...
I also wonder about airshows like Oshkosh where they typically have you turn off your transponder due to traffic density in the arrivals...
Doug
N208LG
PA23 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote PA23 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2020 at 4:23pm
Oshkosh no longer has the requirement to turn off the transponder, at least it wasn't there last year.
Edited by PA23 - 31 Jan 2020 at 7:12pm
