  New Posts New Posts RSS Feed - Self Swap 540 to 550
Roger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Quote  Post ReplyReply Direct Link To This Post Topic: Self Swap 540 to 550
    Posted: 21 Aug 2019 at 4:21pm
Okay, so I just purchased the Gary Reeves IFD mastery course.....Can I seriously buy a 550 and remove my current 540 myself and do a self swap and make the apropriate logbook entry without an avionics shop?  He didn't specifically used that example, he specifically used the example of Garmin 530 swap out to IFD 540.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2019 at 9:17pm
I swapped my 540 for a 550 back in 2017 and it was very easy, step by step instructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2019 at 9:25pm
Oh cool...and you did it yourself without an A&P?
XPRSAV8R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XPRSAV8R Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2019 at 10:30pm
I removed my 540 and installed a 550, last year. It's literally a physical remove, physical insert and manual/auto configure job. No rewiring or modifications. Be sure to take pictures or record settings, or export your configuration to a USB drive before removing your 540. This will dramatically simplify the upgrade task.
Edited by XPRSAV8R - 22 Aug 2019 at 10:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 11:01am
Careful guys.  540 to 550 is not covered in the self exchange.  The 550 has an ARS that needs to be calibrated and that's a maintenance action that must be appropriately signed off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roger Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2019 at 6:35pm
Thanks Steve.
This page was generated in 0.095 seconds.
