  New Posts New Posts RSS Feed - removing USB stick
removing USB stick
Cruiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Topic: removing USB stick
    Posted: 02 Jul 2019 at 10:28pm
what is the proper way to remove the USB memory stick after updating the unit with NavData ?
When can the USB be safely removed?
donemory View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donemory Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 8:30am
You can safely remove the Memory Data Stick as soon as the unit starts to reboot...I do this all the time & I have no problems.
Edited by donemory - 03 Jul 2019 at 8:32am
Don
Alouicious View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alouicious Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2019 at 9:41am
Agree with Don.
After the countdown to reboot, while the screen is black, I try to pull the USB memory.
However, if you are distracted and leave it in, the IFD will boot up normally.  Pull it anytime after that.  Though you could probably pull it anytime after 'Done' is displayed.
At least that's the way it was before 10.2.3.1  The new PM may have specific directions...
Be happy! Your choice.
This page was generated in 0.123 seconds.
