  New Posts New Posts RSS Feed - IFD rubberband reboot issue
dieselcam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dieselcam Quote  Post ReplyReply Direct Link To This Post Topic: IFD rubberband reboot issue
    Posted: 25 Jun 2019 at 12:56am
Got my aircraft out of the shop today after an extensive annual.
During the process my IFD540 was exchanged under warranty.  In another post I asked about config issues and SVS issues.  Got a file today and this is all sorted.
The issue today is this.
First flight after annual, always a little "pucker" on the roll.  On climb out I was directed to route around the Bravo airspace here near Calgary.  A route I have flown dozens of times.  As I was making the 180 turn from 35 heading south to the fix I rubber banded the line to the spot.  I released the line and hit enter.  The screen went blank.  I quickly switched my audio panel to the 440 and entered the tower frequency.  They immediately told me I had quit squawking. I have the remote 332 transponder connected to the 540 and when it went off so did the transponder.  When it booted back up I reentered the code and away I went.
Tonight at home in my hanger I decided to update the databases and install the file to unlock the SVS feature.
I was doing some setting on the replacement 540.  Setting up the data blocks the way I like them. I also entered some common routes into the FMS.  As I was doing this I decided to see if I could save the fix for the "Priddis Route" as it is known around the Calgary Bravo into Springbank airport.
I loaded the route from the FMS and then went to the map page.  I zoomed the map and then rubberbanded the line to "Priddis Corner" within in 2 seconds of removing my finger the screen went blank and the IFD rebooted. WTH I thought.
I decided to see what the 440 would do.  I loaded the same route and did the same rubber band.  A soon as I took my finger off the screen it went blank and rebooted too. I tried several different routes that I fly regularly and it is the same on both the 540 and 440.  As soon as I move the magenta line and move it and remove my finger the IFD shuts down and reboots.  Kind of scary done and IFR flight with this going on.
Anyone in Avidyne Live land experienced this issue?
Latest software installed in the 440 by my shop.  The replacement 540 came with the latest software.
cam
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 6:29am
Definitely no bueno that you're having this problem.  However, I think it's a "good thing" that it's repeatable--hopefully that will make it easy for Avidyne to troubleshoot and resolve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 7:19am
Sounds like a heads-up to everyone to not attempt rubber-banding with 10.2.3.1. :-(
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 8:52am
Cam, can you take video of it happening and send it to me?  I was doing rubber banding just yesterday and it worked just fine for me.  If you have two IFDs, take video of both as the event occurs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dieselcam Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2019 at 11:27am
Hello, sent a bunch to the support line last night.  They called me.  Just headed out to check some things
cam
ChainSaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 7:54pm
Dieselcam and AVI tech personnel,
IFD 440 exhibiting the same overall result while ammending waypoints at FPL page and pressing inner knob, lower right - without using rubber band feature.
Otherwise flawless IFD 440 operations for 1.5 years.
Sequence of actions: 2.7 hours into IFR flight WJF to CCR -> ATC ammends route-> I ammended route accordingly from FPL page-> inserted waypoint using only lower right knob-> pressed inner knob, lower right.....
Result/symptom:
IFD440 screen went completely blank upon pressing inner knob, lower right -> The Avidyne logo was faintly visible (could have been burn in ghost image) -> ifd 440 radio still working/talking to ATC-> IFD then displayed '...Loading Database' (or possibly '... Loading NAV database', not sure was busy flying ifr)-> IFD 440 map screen reappeared without my flight plan activated and without the ammendment I attempted to enter....
This was repeatable 3x - two unintentional and one intentional to verify the problem. First episode as described. Second episode 10 minutes into the return flight. Third episode to verify repeatability 45 minutes into return flight.
Failure theories for response from User's/AVI experts:
1) Hardware failure related to inner knob lower right?
2) Max number of waypoints/ flight plans in IFD?
3) Strange database boundary between NorCal/Socal causing the GPS reboot/'...Loading Database' issue in flight?
Please offer advice/help. I have become fond of the ifd 440, but was horrified when the screen went blank while navigating on an IFR flight plan with my family onboard.
Edited by ChainSaw - 28 Dec 2019 at 8:18pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 10:25pm
That's not enough to go on.  Best to call tech support and open a ticket so we can track it.  First thing they'll do is ask for logs, so if you can get those before calling, it will expedite the process.  Especially need the event log and the date/time of the event.  If you can recall the exact contents of the flight plan and the exact amendment you were attempting to enter, that would be helpful as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2019 at 11:11pm
I will open a ticket and send logs. In the meantime, please let me know the maximum number of waypoints and maximum number of flight plans that the IFD 440 can handle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2019 at 6:14pm
Hello AVI Steve,
I extracted logs and opened a ticket as you suggested.  Below is the info that you suggested:
IFD 440 spontaneously reboots when editing flight plan from FMS and pressing lower right inner knob (R.push):
Event dates and times in Event Log (attached):
(Pilot powers IFD 440 at beginning of flight, loads, and activates route KWJF->KCCR: KWJF PMD EHF AVE PXN MOVDD RBLEW REJOY KCCR)
71595468
20191227
19:53:15
<<<< **** POWER ON **** >>>>
71593759
20191227
19:53:13
HM
ERROR
vm(255) pid(255) code(255) cat(1) sev(3) len(20) - Machine Check Err
71594818
20191227
19:53:14
HM
INFO
PID:19 PersistMainVM1 started (id=1)
71594820
20191227
19:53:14
HM
INFO
PID:27 PersistMainVM2 started (id=1)
(2 hrs 56 min into flight, pilot ammends route from FMS w/ lower right knob, IFD 440 'crashes'):
82195682
20191227
22:49:55
Key
FPSM1
R5L
Press
82195682
20191227
22:49:55
Fms
INFO
Activate leg to REJOY
(uncommanded reboot/IFD 440 crash/screen blank/loss of IFR flight plan/IFD 'reboots'):
82239507
20191227
22:50:39
Knob
FPSM1
R.Outer
-1
82286276
20191227
22:51:26
82285022
20191227
22:51:25
HM
ERROR
vm(0) pid(9) code(30) cat(0) sev(2) len(26) - [SystemMonitor] VM2 STALE
The IFD 440 'crash' sequence repeats , similar circumstances, 10 minutes into return flight next day.
(PIlot powers IFD 440 at beginning of flight, inverts, and activates previous route to obtain KCCR->KWJF: KCCR REJOY RBLEW MOVDD PXN AVE EHF PMD KWJF):
68751276
20191228
19:05:51
68750685
20191228
19:05:50
HM
INFO
68750688
20191228
19:05:50
HM
INFO
70072669
20191228
19:27:52
Pfd
INFO
Weight-On-Wheels State
 IN AIR
( ~ 10 min into flight, pilot ammends route from FMS w/ lower right knob, IFD 440 'crashes'):
70544180
20191228
19:35:44
Key
FPSM1
R6L
Press
70544180
20191228
19:35:44
Fms
INFO
Deleted leg to REJOY
70548272
20191228
19:35:48
Key
FPSM1
R.Push
Press
70549657
20191228
19:35:49
Key
FPSM1
R.Push
Press
70549724
20191228
19:35:49
Key
FPSM1
R.Push
Release
70556719
20191228
19:35:56
Key
FPSM1
R.Push
Release
70556720
20191228
19:35:56
Fms
INFO
Insert waypoint OAKEY
(Pilot also deleted Leg to RBLEW and MOVDD just prior to final R.Push and IFD 440 crash):
70590379
20191228
19:36:30
Key
FPSM1
R6L
Press
70590379
20191228
19:36:30
Fms
INFO
Deleted leg to MOVDD
70590643
20191228
19:36:30
Key
FPSM1
R6L
Release
70595066
20191228
19:36:35
Key
FPSM1
R.Push
Press
70595132
20191228
19:36:35
Key
FPSM1
R.Push
Release
70595383
20191228
19:36:35
HM
ERROR
vm(2) pid(47) code(31) cat(1) sev(2) len(21) - Deadline missed errorng      _
70595383
20191228
19:36:35
HM
WARN
vm(0) pid(1) code(232) cat(0) sev(1) len(30) - VM exited: Virtual Machine 2
70595383
20191228
19:36:35
HM
WARN
vm(2) pid(43) code(31) cat(1) sev(1) len(23) - Deadline missed warning      _
70618336
20191228
19:36:58
70612966
20191228
19:36:52
Persist
ERROR
Repaired KVF/Transient/FreqList.kvb file(s).
70617022
20191228
19:36:57
HM
ERROR
70617685
20191228
19:36:57
HM
INFO
70617688
20191228
19:36:57
HM
INFO
((sequence repeated a third time upon deleting leg to RBLEW, same route, same flight as above):
72707982
20191228
20:11:47
Key
FPSM1
R6L
Press
72707982
20191228
20:11:47
Fms
INFO
Deleted leg to RBLEW
72708179
20191228
20:11:48
Key
FPSM1
R6L
Release
72724019
20191228
20:12:04
Knob
FPSM1
R.Outer
1
72724482
20191228
20:12:04
Knob
FPSM1
R.Outer
1
72724895
20191228
20:12:04
Traffic
INFO
ADS-B Intruder: addr: 3-0x2b0b28 ta:0 lat/lon: 36.91601562/-121.80256653 alt: 825
 misc: 0x9 nic: 6 nacp: 7hvel: 65 vvel: 768 track: 198.3eCat: 0 cs:  mPri: 0 spare: 0x8 appTime: 72727816
72748336
20191228
20:12:28
72747022
20191228
20:12:27
HM
ERROR
72747685
20191228
20:12:27
HM
INFO
72747688
20191228
20:12:27
HM
INFO
There is other weirdness in the logs now that I look, but one issue at a time.  I would be interested in knowing if you/ AVI have seen anything like this.  Could this be caused by a glitch in the latest NAV Data?  Otherwise, nothing else has changed with my system since the GPS rollover update to SW ver 10.2.1.0.A (I do not need and do not want the update after that).  Further, everything has been fine for several months after the 10.2.1.0.A update.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 12:02pm
128 Waypoints and 100 stored routes.  No need to post log extracts here, we'll handle it through tech support.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 10:22pm
Thanks Avi Steve. If 128 is the total number of waypoints for all routes, I was there with approximately 30 total routes stored. What happens to the IFD 440 if 128 waypoints are stored and route editing is performed in flight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2019 at 10:26pm
No, it's 128 waypoints in a route.  The flight plan can have 128, route 1 can have 128, route 2 can have 128, etc.  I'm not yet sure what the cause of your problem is, but it's not a lack of capacity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 2:54pm
AVI Steve or Dieselcam.
What was the resolution to Dieselcam's rubber band reboot issue? Was it ever resolved?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2020 at 9:57am
I don't remember about Dieselcam's specific situation, so he'll have to comment.  In general, we found an issue with rubberbanding in a two box installation when cross-sync was enabled and the boxes had different databases.  That's fixed in 10.2.4.1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2020 at 3:41pm
The purpose of this reply is to recap the spontaneous reboot issue for my IFD440. Avidyne returned the unit after replacing the 'CF' and 'SD' cards  with the unit  under two year warranty, but charged $750 for the 'no fault' found service. The dealer then added 10% plus shipping to that. Now $900+ dollars short, I still have no confidence in the IFD440 and I am certain I will neither buy another Avidyne product, nor recommend Avidyne to anyone else. On a positive note, all of the people I spoke with at Avidyne for this issue were solid characters who were sincerely interested in doing the right thing.
Bob H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob H Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2020 at 9:34am
Hmmm......I find it troubling that repairs were made (replacing the 'CF' and 'SD' cards) and you get charged a no fault service fee.  Also, even if Avidyne was unable to find a fault, do your logs not show something amiss?
This page was generated in 0.135 seconds.
