  New Posts New Posts RSS Feed - IFD100 map won't show track up
RGLADY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGLADY Quote  Post ReplyReply Direct Link To This Post Topic: IFD100 map won't show track up
    Posted: 27 May 2019 at 4:42pm
My map display on the IFD100 won't show track up. When I go to the set up under user options the map orientation is set to track up ,but is gray (ghost) and can't be changed. Am I missing something?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 11:25pm
There are two different settings.
Track up versus Heading up. The latter is only available if you have a heading source from an ADHARS for example. I expect you don't, and that is why it is fixed to Track up.
What you are likely looking for is to toggle from Track up (centered), Track up (2/3rd view) and Mag North up. Just click the right button in while in MAP view, to move between these.
This is a very common question from new users. Enjoy your IFD!
Edited by oskrypuch - 27 May 2019 at 11:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGLADY Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 3:27pm
Orest,I know how to do it on the panel mount. Im on the IDF100 app on my IPAD. Which button(key) on the right are you referring too?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 6:00pm
You use ENTER, when on the MAP page.
Edited by oskrypuch - 28 May 2019 at 6:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote RGLADY Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 12:45pm
Got it. Thanks!
