  New Posts New Posts RSS Feed - IFD100 issue post update
Flybuddy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Topic: IFD100 issue post update
    Posted: 22 May 2019 at 11:15am
Got the following alert today on the app while trying to sync a flight plan:
"FPL xSYNC DISABLED"
I double checked that both 440 and IFD100 had same databases and the NAV, OBSTACLES and TERRAIN all match but on the IFD100 it shows:
"CHARTS UPDATE REQUIRED July 1, 2016"
When I go to the update page on the IFD100 there is no "CHARTS" listed as an option.
I'm a new IFD owner so I'm still on the free 60 day package from Jepp.
It did work and sync properly prior to the update..Any suggestions appreciated...thx
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 11:17am
You need to update your IFD100 to the newest version.
edanford View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote edanford Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 12:08pm
Not May 23 until this evening. (UTC)
Yellow will go away tonight
Loading new data too soon will show yellow just as having out of date data
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote edanford Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 12:30pm
You also have to make the Ipad with the IFD100 one 2  allowed subscribed to charts with Jepp if you have that level plan.
There is a setup page in IFD100 with Jepp to do this.
The charts update does not automatically appear on  IFD100 otherwise
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 1:34pm
Steve--I don't show any update for the IFD100 available, should I delete it and reload?
I'm a new customer and still on the 60 day trial--does that even include charts? (I don't see any past chart downloads on JDM)
Edited by Flybuddy - 22 May 2019 at 1:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 1:40pm
On the app store, it's version 10.2.7.  Is that what you have installed on your iPad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 1:53pm
On the Aux software status page it shows s/w ver# 10.2.2.0.A.. There is no update showing as available on my App Store page. Will I lose connectivity if I delete the app and reload it?
Also, do you know if charts come with the 60 day trial?
Post Options Post Options   Thanks (0) Thanks(0)   Quote edanford Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 1:58pm
No,  I had to do the same thing.
I deleted the app and re-loaded from App store to get to latest version
You might have to re-install  Nav data and obstacles
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 1:58pm
I searched app and it showed an update available after I queried the version history BUT it only let me update to 10.2.3.1
Thx ED, just saw your post...I'll delete it
OK--I deleted it and it reloaded 10.2.3.1
Edited by Flybuddy - 22 May 2019 at 2:01pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 2:16pm
There is a note on the app store that says it is best to upgrade to 10.2.3.1 before updating to 10.2.7. I've tried deleting and reinstalling several times now and it still will only give me 10.2.3.1 even if I download the databases also. Do I need to sync it first with the 440?
Post Options Post Options   Thanks (0) Thanks(0)   Quote edanford Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 2:39pm
If the IFD100 showed 10.2.0.0.A before and now it shows 10.2.3.1 on Aux page it should now data share with your IFD440 running 10.2.3.1
My IFD100 shows 10.2.3.1 on Aux and shares with my updated IFD540 without issue
Ed
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 2:55pm
Thx much ED!
p.s...I spoke with Jepp, the 60 day trial does not come with charts
Edited by Flybuddy - 22 May 2019 at 2:57pm
AZ Flyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 9:48pm
Do I understand that you are using just an IFD440?  If so, that suggests to me that because charts aren't available on the IFD440, you don't have the IFD100 app correctly configured for the IFD440.  In other words, there should be no message concerning charts on the IFD100 app if correctly configured as an IFD440.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2019 at 9:55am
Good point--if you go into your IPAD settings and scroll down to the various apps, then select IFD100, you'll see just 3 items to set and the default is IFD550. I've changed it...thx for the heads up
GRINGODS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GRINGODS Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2019 at 10:01am
Scrub the IFD100 from your iPad then reinstall from the apps store. As some of the data files may be removed you may have to reinstall them. Had the same issue yesterday P.S. large text is a great improvement!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flybuddy Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2019 at 1:11pm
Flew with it today, no messages and everything works!
