  New Posts New Posts RSS Feed - IFD540 simulator and bluetooth keyboard
PeterC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Topic: IFD540 simulator and bluetooth keyboard
    Posted: 02 May 2019 at 10:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 9:14am
Thanks for all kind words and +1s ! It's my pleasure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 8:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 9:47pm
+10
Lachgn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lachgn Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 8:36pm
+1!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 7:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 7:31pm
Not related to kbd, Steve, but I think speaking for most if not all on this board, your efforts to keep communications and information flowing is very much appreciated.  Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 9:49am
The keypresses from the bluetooth keyboard get intercepted by iOS before they get to the trainer app.  As you noticed, some keys get sent to us as we expect (e.g. letters, numbers) but others don't.  You just have to keep those limitations in mind when using the BT keyboard and the app.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 10:16am
I haven't tried it but I'm not sure it was ever intended to be used with the trainer.
bcool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcool Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 9:54am
Following up...some of the keys work, but it seems like the ones in the top row don’t (like the direct-to button, for example). Weird how it adjusts the iPad volume instead of simulating the direct-to function).
Post Options Post Options   Thanks (0) Thanks(0)   Quote bcool Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 7:04pm
Does anyone have the Avidyne bluetooth keyboard working with the 10.2.3 iPad simulator?
It seems to be connected, but when I press keys on the keyboard I get random results...for example direct-to does a volume-up command on the iPad.
