IFD 440 and GDL82 Failing ADS-B SIL |
markpavinich
Newbie Joined: 06 Apr 2018 Location: Monroeville Status: Offline Points: 12 |
Posted: 25 Apr 2019 at 5:03pm |
Need help with the particular scenario: IFD440 GDL82 Configured ADS+B G2 format SIL is failing almost at 100% Everything else passes without any issuess. On the ground, everything appears to check out. Let me know if I am missing anything. Thanks.
Tech support says that the IFD440 is not an approved position source for the GDL82. That's why it's failing the SIL and is not covered by our STC.
eallevato
Groupie Joined: 04 Apr 2018 Location: Northridge, CA Status: Offline Points: 69 |
Steve
Something does not seem right. The IFD440 according to Avidyne is a slide in replacement for the 430W. To me, that means that it is form, fit and functionally equivalent to the 430W. Tech support’s answer basically says “well, we are almost functionally equivalent”. SIL is a function of the transponder and in this case the GDL82. It seems to me that the GDL82 is not configured correctly. I would go back and ask engineering, instead of tech support. Gene
Gene
mfb
I don’t think that this is an Avidyne thing. It’s a Garmin thing. They control the GDS 82, and they don’t approve position sources other than their own equipment.
See their official approval list at http://static.garmin.com/pumac/190-01533-00_06.pdf . The document states that any other position sources must meet the requirements of AC 20-165B. I have no idea what’s involved with establishing that, but I imagine it’s not trivial and it will be hard to do without Garmin’s cooperation. Note that Avidyne DOES approve Garmin position sources for the AXP340 transponder, but the reverse is not true. Mike
Edited by mfb - 28 Apr 2019 at 7:21pm |
Cruiser
from the FAA AFS-360 requirements How can the ADS-B OUT system obtain initial approval? Initial ADS-8 OUT system pairings (transmitter/GPS) must be approved for installation using the Type Certificate (TC), Amended TC (ATC), or Supplemental Type Certificate (STC) process. Consult your Aircraft Certification Office to determine the appropriate approval process for these initial installations. Once the performance of the initial pairing has been established, the FAA considers follow-on installations of the same pairing to be approved. Organization Designation Authorization (ODA) holders can issue ATC and STC when authorized by their FAA Organization Management Team (OMT).
Cruiser
Don't all GDL 82 units come with an internal GPS source?
sounds like the only option is to mount the included GPS antenna and run the cable to the unit. Most of them are installed that way. |
eallevato
The 82 comes in 2 flavors, with and without internal GPS.
Gene
