  New Posts New Posts RSS Feed - Loss of Fuel Flow, Fuel Rmg, & % Power
TxCirrusDriver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TxCirrusDriver Quote  Post ReplyReply Direct Link To This Post Topic: Loss of Fuel Flow, Fuel Rmg, & % Power
    Posted: 18 Feb 2019 at 3:02pm
Mid-flight I've had this issue come up several times now with my Avidyne Entegra MFD & PFD where the fuel flow information, fuel remaining, fuel used, and power percentages have gone out on my MFD (engine & maps page), and PFD (lower right box showing fuel flows and upper left showing power %). It has now happened 3 of the last 4 flights, at varying flight times from 15 minutes of flight to 2+ hours of flight before it went out on me.
Has anyone else experienced this issue?
I am thinking it could be a connector issue mainly as EGT/CHT information is all working just fine, and all other items are working fine with the PFD/MFD presently.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catani Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2019 at 4:44pm
Sounds like a fuel flow transducer failure.  A small thumb-shaped box in the fuel line between the fuel pump and spider.  It has a spinning wheel inside that digitizes the amount of fuel being consumed by the engine.  Mine failed a while ago with similar symptoms.
