  New Posts New Posts RSS Feed - Fuel Remaining Calculation
jveatch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jveatch Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Remaining Calculation
    Posted: 15 Jan 2019 at 11:54am
In my 1977 Cardinal RG, I find that THE most reliable indication of fuel remaining is the amount shown on the Avidyne IFD550.  This has been verified by repeated physical measurements on the ground of each fuel tank with a calibrated stick, and certainly NOT by the fuel gauges in the aircraft.  However, I do find that when I fill up fuel, the amount I am able to add is about 5% more than I would have expected based on the indication on the IFD550.  What is the procedure that I can use to modify the calculation the IFD550 is using based on fuel flow?
jveatch
Cardinal RG N177JV
Post Options Post Options   Thanks (1) Thanks(1)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 2:39pm
You would need to make the adjustment in your fuel flow device, the so-called K-factor.
The IFD just accepts the data it sends.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jveatch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2019 at 3:09pm
Thank you!
jveatch
Cardinal RG N177JV
