  New Posts New Posts RSS Feed - EX500 sw 8.2 interface to GDL-88, 430W
Byron View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron Quote  Post ReplyReply Direct Link To This Post Topic: EX500 sw 8.2 interface to GDL-88, 430W
    Posted: 20 Dec 2018 at 6:06pm
I have an EX500 and would like to remove the satellite XM interface and use the ADS-B weather and traffic information on my EX500.  I cannot get a straight answer from anybody as to whether or not the SW version 8.2 in the EX500 will communicate with either the GDL-88 or the Garmin 430W to display the FID-B information.   Does anybody have experience with this system configuration?   Results?
Byron Allen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2018 at 9:16am
The answer is most likely yes. The best way to find out for sure is to contact Avidyne tech support directly
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2018 at 11:08pm
Unfortunately, I called Avidyne and they told me to call Duncan.  I called them and they had no idea if the requested configuration with the GDL-88 would work.
Byron Allen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 7:17pm
For EX500, it is release 4.2. You should check with Garmin if the GDL 88 provides Capstone-standard ADS-B IN protocol and ADS-B/ADS-R/TIS-B Traffic using ARINC735 protocol.
This is from the Avidyne website:
https://techsupport.avidyne.com/portal/kb/articles/ex500-ex600-mfd-software-4-2-faq-s
EX500/EX600 MFD Software 4.2 FAQ's
For EX600 & EX500 MFD-equipped aircraft:
•For ADS-B OUT
-Avidyne offers IFD4XX/IFD5XX FMS/GPS navigators for approved GPS position source
-AXP340 Panel-mounted or AXP322 Remote-mounted Mode S Transponder
•For ADS-B IN
-EX500/EX600 MFD customers can now upgrade to R4.2 MFD software
-R4.2 adds display capability of FIS-B Weather using Capstone-standard ADS-B IN protocol and ADS-B/ADS-R/TIS-B Traffic using ARINC735 protocol.
-Avidyne offers SkyTrax100 Series ADS-B IN Receiver
-R8.2 also adds compatibility with 3rd-party systems including Lynx NGT-9000, Garmin GTX345, FreeFlight RANGR-RX, or other Capstone/735-compatible ADS-B IN receivers.
Q: What's Included in R4.2?
•Adds support for Avidyne ADS-B IN weather products using on EX500 & EX600 Series MFDs
-Supported ADS-B/Wx products include NEXRAD, SIGMETs, AIRMETs, winds and temps aloft, METARs, and TAFs, plus TFRs
•Allows EX500/EX600 MFD to display ADS-B Traffic when wired to a compatible ADS-B receiver that provides traffic via ARINC 429/735 protocol
-MFD will display legacy TAS symbols, not ADS-B directional traffic
•R4.2 is specifically for the support of ADS-B and is not required or recommended for any other reason.
Q: What's removed in R4.2?
•R4.2 removes support for Sirius weather from the MLB700
•R4.2 removes support for Iridium-based satellite weather from the MLX770
•If you are currently using either of these systems and want to continue to do so, do not upgrade to R4.2 as you will not be able to go back.
•(Note: support for XMD-076/A is NOT removed)
Q: Can I use a 3rd Party ADS-B Receiver (GTX345, L3 NGT9000 Lynx, etc) with R4.2?
•A: Yes. In addition to adding compatibility with the Avidyne SkyTrax 100 Series ADS-B receiver, R4.2 will allow your EX500/EX600 MFD to display the same weather products from a GTX345, Lynx NGT-9000, Free Flight RANGR-RX, or other Capstone-compatible ADS-B IN Rcvrs.
Q: I currently have a TAS6XX series traffic system, can I still use the TAS AND get ADS-B In traffic?
•A: Yes. Avidyne’s new SkyTrax600 (aka TAS-A Release 2) allows TAS6XX series customers to upgrade to SkyTrax600 capability which blends Active-surveillance (TAS) traffic combined with passive (ADS-B IN) traffic for display on your EX-series MFD
Q: I currently have a SkyWatch TAS, can I still use the TAS AND get ADS-B In traffic?
•A: Customers will need to choose between SkyWatch TAS and ADS-B traffic on the MFD in Maintenance Mode. This is not selectable by the pilot. Some customers are displaying ADS-B Traffic on their GPS display and keeping their SkyWatch displayed on the MFD (or vice versa). For now, Avidyne recommends keeping your SkyWatch TAS for traffic as most aircraft are not ADS-B out equipped yet. There are some ADS-B IN/OUT transponders that accept Skywatch/TAS input and blend it with ADS-B traffic on the ARINC 429 output, in which case the EX MFD would display both.
Q: I lost my Sirius weather when it was terminated by WSI/Sirius XM, do you offer a satellite-based weather solution?
•A: No, we currently do not have a replacement for the MLB700. With the proliferation of ADS-B in the market, we have not made any specific plans to develop a replacement for the MLB700 at this time. If you prefer a satellite-based weather solution we recommend a portable receiver and an iPad as a solution. Currently, the SiriusXM SXAR1 is available from Sporty's for $399 after rebate.
Q: I currently have an XMD-076 XM receiver in my airplane. Do I need to remove it to get ADS-B weather?
•A: During configuration, you have to select one datalink weather source to the EX500/EX600 MFD from the XM receiver or from the ADS-B IN Receiver, but you cannot have both. Some customers want to remove the XM and get rid of the subscription fee associated with that service, while some other customers are choosing to leave the satellite-based XM connected to their EX-series MFD and displaying ADS-B weather on their Avidyne IFD4XX/5XX GPS Navigator display (or elsewhere). It really all depends on pilot preference.
Q: I already have a GTX345 in my airplane. Will R8.2 allow me to display ADS-B Traffic & Weather from the GTX345 on my MFD?
•A: Yes. This also holds true for any other compatible 3rd party ADS-B receiver (Lynx/RANGR) that is already installed.
Q: Will Avidyne feature a promotional pricing with the launch of R4.2?
•A: Yes. We are currently running a promo for customers who purchase an IFD550 with a Lynx NGT-9000 from Avidyne, we will also include the R4.2 software upgrade for free for your EX500/600 MFD.
Q: Do I need to send any hardware in to Avidyne?
•A: EX500 & EX600 MFDs must come back to Duncan Aviation for updating. Please note the R4.2 upgrade is not covered under warranty.
Q: How much does R4.2 cost?
•A: Please contact Duncan Aviation for pricing and scheduling. Additional costs may be associated with the upgrade. Contact Duncan Aviation for details at 800-562-6377.
Edited by AviSteve - 04 Nov 2019 at 4:47pm
Melohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Melohn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2018 at 5:02pm
You’d need the GDL-88 install manual to determine what formats it outputs; it does have ARINC 429 and several rs232 ports, so if you can configure it correctly, it’s likely to be able to communicate.
