Programming alternate missed |
Post Reply ![]() |
Author | |
rolfe_tessem ![]() Senior Member ![]() ![]() Joined: 06 Jan 2012 Location: Massachusetts Status: Offline Points: 191 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Dec 2018 at 8:40pm |
So, one of my local airports, Albany, NY has had their standard missed approaches for the ILS 1 and ILS 19 NOTAMed out for some time due to the CAM VOR being out of service.
The NOTAM provides alternate missed approaches for both runways. In the case of ILS 01, it is "Climb to 2000, then climbing left turn to 4000 on ALB VORTAC R-299 to MARIA/ALB 19 DME and hold" In the case of ILS 19, it is "Climb to 2000, then climbing right turn to 6000 on heading 2000 and ALB VORTAC R-194 to GROUP/ALB VORTAC 11 DME and hold". I have tried with the simulator and have been unsuccessful with getting either of these programmed. Is it possible to delete the miss in the database? Apparently not. Even adding it at the end of the flight plan, I can't make it work. I have not tried it in the airplane... Any suggestions here? Rolfe |
AviSteve ![]() Admin Group ![]() ![]() Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2302 |
The FMS loads missed approaches as part of loading an approach, since the database contains only one missed approach for each approach.
Avidyne Engineering |
Steve, I get that...
So, how do I program the alternate missed that I outlined above? I get that I can't delete the canned one. I would have thought that I would add MARIA to the end of the flight plan, figure the reciprocal of the radial from ALB and add that to the MARIA waypoint via the OBS. The simulator would not let me do that. Rolfe |
OBS is a tactical function. There's not a corresponding kind of leg that you can add to the flight plan (outside of an approach).
The best way for you to enter the alternate missed for ILS 01 is to put the cursor after the missed approach, add waypoints ALB and MARIA, then hold at MARIA. When you go missed, start the climbing left turn, then activate the leg to MARIA (using L1 "Activate Leg"). Similarly for 19, add ALB, GROUP, then hold at GROUP.
"OBS is a tactical function"
Hmmm, might be nice to put something about that in the manual. So, if the alternate miss in question hadn't had a named intersection, but instead just a DME/19 on the ALB R-299 radial, how would one program that? A user waypoint? Rolfe
Gring ![]() Senior Member ![]() Joined: 30 Dec 2011 Location: Kingston, NY Status: Offline Points: 739 |
Rolfe,
In that situation, you could program a user waypoint, however, that would best be done during the enroute phase of flight, and not while on the approach - a workload issue. If you found yourself on the approach with those instructions, you can OBS the ALB VOR and use a datablock to find 19 DME. You can always switch to VLOC mode and use the green/white radial/bearing indicator to set the 299 radial and use a datablock or a tual DME (if equipped) to find 19 DME. I think we sometimes forget basic navigation skills and rely on the GPS too much.
Edited by Gring - 11 Dec 2018 at 6:19am |
Yes, you could define a user waypoint using Radial/Distance format.
Edited by AviSteve - 11 Dec 2018 at 10:10am |
MysticCobra ![]() Senior Member ![]() ![]() Joined: 29 Jan 2013 Status: Offline Points: 677 |
Unfortunately, there are some situations that require a big more "fiddling" to handle, as this example illustrates. Understanding where those corner-case limitations are is important, but it can be hard to develop that understanding without running into those corner cases, which sometimes comes as a rude surprise. I'm not sure that's a manifestation of "forgetting basic navigation skills". I think it's more a case of recognizing the limitations of the $15,000 FMS, where reverting to the 50-year-old tech and "basic navigation skills" may be a better option.
Well, this is one reason I left a traditional NAVCOM with it's own CDI in my plane alongside the 540. Sometimes, in situations like this, it is just easier to twist a knob to the correct radial and fly the raw data.
Rolfe |
FlyingCOham ![]() Senior Member ![]() ![]() Joined: 30 Oct 2015 Location: COS (KFLY) Status: Offline Points: 125 |
We kept an old KNS80 NAV system (enroute & approach VOR, DME, enroute & approach Rho-Theta RNAV) when we upgraded to Avidyne. Great backup and very useful in situations like this. "DME/19 on the ALB R-299 radial" is a breeze. Set 111.2 (ALB's freq), set 299, set 19, spin the OBS to 299, set the A/P to the KNS80 & watch.
Jim Patton
Bob H ![]() Senior Member ![]() ![]() Joined: 26 Jan 2018 Location: NH - KMHT Status: Offline Points: 290 |
I’ve always been a strong believer in not trying to program everything into the IFD, especially in high workload or congested airspace. Sometimes the best course of action is to resort to raw data. However, I don’t consider these situations to necessarily indicate a limitation of the IFD. What I see are “corner cases” of rare clearances that cause “programming confusion”, especially if it requires rarely used IFD features. For example, this thread began due to the alternate missed approach clearance: “intercept the ALB VORTAC R-299 to MARIA/ALB 19 DME and hold as published." If the clearance had been instead: “intercept the leg between ALB and MARIA to MARIA and hold as published”, I suggest that the thread never would have been started. We are all familiar with programming course legs. But in the world of GPS, we rarely get “intercept radial”. The confusion is in translating from radial programming to leg programming. Once that translation is clarified, it becomes no different than programming any revised course clearance.
So, I don’t see a limitation of the IFD in these examples. What I see are “corner cases” of rare clearances that cause “programming confusion”, especially if it requires rarely used IFD features. Reverting to raw data in these situations is absolutely the right thing to do. It’s what I do when I encounter a situation that isn’t immediately clear about how to program the IFD. The value of this forum is that we can discuss and learn about how to eliminate our limitations before we encounter them in the aircraft. I can also practice them on the simulator so that they will eventually become a part of my flying DNA and minimize my having to revert to raw data. Edited by Bob H - 12 Jan 2019 at 5:02pm |
Post Reply ![]() |
Tweet
Forum Jump | Forum Permissions ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
