  New Posts New Posts RSS Feed - tune VOR freq from FMS
doog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doog Quote  Post ReplyReply Direct Link To This Post Topic: tune VOR freq from FMS
    Posted: 21 Nov 2018 at 7:26pm
When you've loaded a flight plan in the FMS and one of the waypoints is a VOR, is there a quick way to highlight the VOR in the flight plan and tune it?  I couldn't figure out a way other than going to the INFO tab and typing in the letters to bring up the info page, then highlighting the frequency and hitting enter.  I'm sure there is a faster way?
Edited by doog - 21 Nov 2018 at 7:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2018 at 8:12pm
VORs that are set in the flightplan will auto-tune as the waypoints sequence.
If you need the VOR tuned before then, then just touch the VOR standby position, and type in the VOR identifier, swap, done. You don't need to go to the INFO page, etc.
Edited by oskrypuch - 21 Nov 2018 at 8:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 9:17am
Another easy method if the desired VOR is not already auto-tuned is to display the NRST VORs using the NRST button. Then either double tap on the desired VOR to put it in the standby VOR position, or rotate the lower right selector knob to highlight then push to select the desired VOR into the VOR standby position. Now swap the VOR from standby to active using the frequency swap button.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 11:35am
All good suggestions.  Another is to move the cursor around the VOR in the flight plan, then go to the info page and press "Paste" on L1.  That keeps you from having to type in the letters.
Bob H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob H Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2018 at 1:30pm
And finally, if an airport is on the INFO page, there is the sub-menu of "Nearby Navaids" that can be used.
doog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doog Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2018 at 3:41pm
thanks guys, good tips
