  New Posts New Posts RSS Feed - Aural terrain alerts, can they be disabled?
motoadve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote motoadve Quote  Post ReplyReply Direct Link To This Post Topic: Aural terrain alerts, can they be disabled?
    Posted: 02 Nov 2018 at 9:15pm
I fly lots of backcountry , and may places I land are not charted other are not even airports.
Is there a way to get rid of the terrain aural alerts?
IFD 550
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2018 at 10:56am
on the setup page, user options
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 9:13am
Also, see "DESIGNATING A USER WAYPOINT AS AN AIRFIELD" section in the Pilot's Guide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote motoadve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 9:22am
I want to get rid of the 500ft aural alert, even if I turn volume down , still there.
Is there a way to do this?
I added my airport as an airfield, but I do land on beaches and gravel bars too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 9:26am
You can designate any user waypoint as an airfield, so create one for you favorite spot on the beach and/or your favorite gravel bar and it will still work.  As chflyer pointed out, the 500ft Callout Aural can be disabled on the User Options page.
Post Options Post Options   Thanks (0) Thanks(0)   Quote motoadve Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2018 at 9:33am
Thanks will look into it.
Jamorowitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamorowitz Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 4:40pm
This may not be the most elegant solution, but I had my shop wire the Avidyne audio to a separate switch on my audio panel. I can silence all the terrain and altitude alerts on low level VFR flights with the flip of a switch. Its quick and easy to select the appropriate choice depending on what type of flight I am on.
Flying_Monkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Flying_Monkey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2019 at 5:09pm
I was thinking about this and maybe this would work— set up another user profile with all the identical options to your main profile except in user 2 turn off the aural warnings like 500 foot callout, terrain, etc (choose which ones). Then for flights or segments of flights just switch to user 2. It’s the top menu choice so no scrolling and is very fast to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2019 at 7:16am
I think the best option is to install a TAWS annunciator panel which has an inhibit button that will inhibit TAWS. Something like this, which you can find used for $500
https://www.mcico.com/md41-1028-md41-1028-new
Post Options Post Options   Thanks (0) Thanks(0)   Quote programmer@pcmforles Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2019 at 8:36pm
Unused DME audio input wired to aural alerts, relabeled ALERT seems like an idea that would work well.   Reach up and turn it on or off as desired.
