  New Posts New Posts RSS Feed - default chart is not the selected approach
doog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doog Quote  Post ReplyReply Direct Link To This Post Topic: default chart is not the selected approach
    Posted: 05 Oct 2018 at 6:24pm
A little new to the IFD 540 coming from the Garmin...  When I hit the PROC button and load a procedure, and then I tap the map button and rock it right to go to the Chart, the selected chart is not the approach I just selected.  Often it's still on the source airport taxi diagram.  I can sometimes "paste" the correct airport using the LSK, and then hunt for the approach, but on other systems I fly the chart defaults to the selected approach...  am I doing something wrong?
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2018 at 11:48pm
The procedure you select is separate from the approach plate.  You must  still select the correct airport and then choose the approach plate you want to view even though you selected an approach in the flight plan.
Edited by teeth6 - 05 Oct 2018 at 11:50pm
