  New Posts New Posts RSS Feed - Missing Waypoint?
Missing Waypoint?
PA20Pacer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Topic: Missing Waypoint?
    Posted: 17 Aug 2018 at 10:17am
Hello All-
On the Bonanzas to Oshkosh flight, the waypoint TABMY was added to the planned route on the day of departure. This waypoint was not in my IFD540 database, but was in Foreflight and in the Jeppesen database on my Trimble 2000 Approach Plus. I stopped by the Avidyne booth, and the representative pulled up the waypoint on an IFD440 in the display booth with no problem, and we concluded that I probably had a corrupted database.
I have since re-downloaded the 1808 database, and downloaded the 1809 database, and TABMY is still nowhere to be found. That is also true for the IFD Trainer app on my iPad, which has the 1809 nav database. I have tried to determine what role TABMY plays in the airspace system, and according to Airnav, it seems to be an RNAV waypoint in a special instrument approach procedure.
This is not a big issue, since I suspect that any waypoint that I am likely to actually need to use will be in the database. However, I am curious about why I cannot find it, since it seemed to be in the database of the unit in the Avidyne display booth. Perhaps there is some setting active in both my IFD540 and the trainer app that prevents this waypoint from being accessed, but I cannot imagine what that would be.
I am curious about whether others can see this waypoint, and whether anyone has any thoughts about why I may not be able to find it.
Best,
Brookeridge Airpark (LL22)
Downers Grove, IL
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 1:00pm
What database coverage area do you have?  Americas? USA?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2018 at 3:46pm
Hi Steve-
Sorry I failed to mention that. It is Americas coverage for Navdata on the IFD540. The coverage on the Trimble is Full USA.
Please understand that this is not a complaint, and I am not expecting Avidyne to drop the important work that they are doing on various product enhancements to answer this question. If there is a simple answer, though, I would like to be aware of it.
Downers Grove, IL
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 10:12am
Turns out that TABMY is a terminal waypoint associated with a copter approach to a hospital heliport (WS70) in Beaver Dam, WI.  That would explain why it appeared on the IFDs in the booth - they had a helicopter database loaded.
Including helicopter data in the standard database is something that's been on my to-do list.  Coincidentally, I had a couple of other related issues in the last day or two that took it to critical mass, so I just wrote to Jeppesen to get the process started.  It probably will take a cycle or two for it to be included.
At that point, if the Bonanza group again opts to use a helicopter waypoint for some reason, you'll have it in your IFD.
Edited by AviSteve - 22 Aug 2018 at 10:13am
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 10:39am
While you're talking to Jeppesen, I understand that if you get a Garmin 430 subscription, they throw in a seat for charts on your iPad. Any chance the same could be done for Avidyne devices. at least for an IFD-440 subscription, but preferably also for the 540?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2018 at 4:06pm
Hi Steve-
Thanks for solving the mystery. I has a feeling that it might be associated with a helicopter approach to WS70, and tried identifying my aircraft as a helicopter on the IFD540 setup pages, but that did not do the trick. I did not realize that there was actually a different database for helicopters.
One never knows to what nefarious uses some of these obscure waypoints may be put.
Best,
Downers Grove, IL
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 9:25am
I thought this was done-- if you have Jepp charts for any of the IFDs you should be able to use the Jepp charts in Foreflight, and/or in the IFD100 app. Are you not seeing that behavior?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 10:30am
We may be talking about something different. If you buy a navdata/obstacle bundle for a Garmin 430, you get a no-cost charts subscription for use on an iPad. I think the seat can be used with a selection of EFB's, but only one one of those EFB's. You can't display charts on a 430. The bundle costs about what a similar navdata/obstacle bundle costs for an IFD-440.
AZ Flyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AZ Flyer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 2:23pm
Consumer tip:  You can get the IFD440 subscription for the IFD540.  Just order that upfront and avoid the hassle of getting a sales person who thinks you have to have the charts subscription if you have a 540.  The EFB charts would be a nice bonus.
Edited by AZ Flyer - 23 Aug 2018 at 2:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2018 at 4:19pm
I called Jeppesen today to change my subscription. Here's the latest information I could get:
I had a subscription for Americas NavData and Obstacles for the IFD-540. It cost $788. I had it because I flew to Mexico earlier this year.
IFD-540 Prices:
Whole US NavData/Obstacles: No bundles available. NavData is $480 and Obstacles $185 or $665 for both.
Whole US NAvData/Obstacles/Terrain and Charts: $940
IFD-440 Prices:
Whole US NavData/Obstacles/Terrain bundle: $564
Terrain hasn't changed since 2015.
EFB seat for charts: $199. Better to buy the seat from Foreflight if you use that. Theirs includes use in a couple of Pads and a phone. The Jepp license is for one device.
GNS430W: Their bundle includes a seat for charts for an EFB. The GNS430W itself doesn't get charts The rep claims this was an enticement since Garmin also offers their own nav data. The previous rep said this was a negotiation between Garmin and Jeppesen. I didn't get into the pricing but it is in the $400-$500 range.
Edited by HenryM - 23 Aug 2018 at 4:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2018 at 10:47am
Thanks, Henry. I misunderstood-- when you buy charts for the IFD you can use them in FF/IFD100 seats. You were pointing out that buying navdata for the 430 also gave you a chart seat.
Fun fact: your quoted prices for charts are about $200 less than what I was quoted for the same product, which is why I ditched the chart bundle and went navdata/obstacles-only using the 440 package.
This page was generated in 0.258 seconds.
