  New Posts New Posts RSS Feed - IFD440 with 330ES TIS traffic issue
intrepid04 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote intrepid04 Quote  Post ReplyReply Direct Link To This Post Topic: IFD440 with 330ES TIS traffic issue
    Posted: 29 Jul 2018 at 11:33am
Before I upgraded from the 430 to the 440 the 430 would show traffic for TIS. The 440 does not seem to do that.
Sometimes it will announce that traffic is unavailable audibly and will say there is traffic audibly but not show anything on the screen even though I have it set to below 40 miles.
Is it a setting I am missing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ibraham Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2018 at 12:44pm
Make sure you have the correct settings in the 440 Main ARINC 429 Config,  Data input
Garmin GTX 330 w/Traffic
Garmin GTX 330 w/TIS This ARINC 429 speed should be set to the high speed.
I believe you will  receive TIS-A traffic only if you are in an area that has the TIS-A radars. TIS-B traffic has significantly wider coverage but you will need and ADS-B in receiver
