  New Posts New Posts RSS Feed - Does my IFD540 have Wifi / Bluetooth & FLTA TAWS?
CubedRoot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CubedRoot Quote  Post ReplyReply Direct Link To This Post Topic: Does my IFD540 have Wifi / Bluetooth & FLTA TAWS?
    Posted: 09 Jul 2018 at 5:55pm
I am fairly new to Avidyne and I have an IFD540 in my Cardinal.
Here is a screenshot of my hardware:  https://photos.app.goo.gl/HV1TMZwRaMarFqPe7
I have tried configuring WIFI and it is set for "LOCAL" but when its in flight mode, I do not see the wifi network.  Same goes for Bluetooth, I can pair my keyboard to the IFD in the configuration screen (even typing in the matching characters to pair), but when I reboot back into flight mode, the keyboard doesn't do anything.
Additionally, I don't seem to be getting any FLTA alerts / notifications on the screen like I see in most of the videos online of the IFD540 in use.
Are those features "enabled" on the screenshot of my IFD I posted above?
Thanks in advance for helping a total newb.
AzAv8r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AzAv8r Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 11:04pm
Welcome fellow Cardinal owner.  Hopefully you are a CFO member.
I've never looked at the options screen critically - all the stuff I expected to work, worked.
But I would conclude from your photo that the screen shows all *possible* options, and the highlighted one ("SVS") is the only one enabled.  Which would mean you do not have WiFi or BT enabled.  The other non-highlighted options are somewhat specialized and would be unusual in a Cardinal.
Hopefully someone more knowledgeable will chime in.  Did you have the 540 installed, or did you purchase the plane with it already installed?  If the former, talk to your dealer/installer.
Seems odd they would work on the ground, but then stop working in the air.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 12:17am
I thought all IFD 540's have WiFi and BT enabled.
Edited by LANCE - 10 Jul 2018 at 2:33pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CubedRoot Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 12:41am
It was already installed when I bought the Cardinal.  I have been all through the options and configuration and can't find where to enable it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2018 at 9:05am
That screenshot shows WiFi and BT are disabled.  Call tech support and they'll get you going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kentucky Captain Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 2:10am
We were flying home and I was trying to connect the IFD100 app to the IFD540 when I discovered that Bluetooth & WiFi both were off.  I had received a replacement IFD540 some time before but had other things going on and hadn't had the need of those features.  As soon as I went into the configuration and turned the Bluetooth on, the "Allow WiFi/Bluetooth" prompt popped up even though I hadn't turned on the WiFi yet.  After Bluetooth, I enabled WiFi but no additional "Allow" prompt came up.  I had a Wifi and Bluetooth logo in the upper right hand corner but could still get no connection between the IFD540 and the IFD100.  We were IFR at the time so I didn't feel the need to reboot the IFD.  By the time we got home I had forgotton about it and haven't had the opportunity to test it since.  I'm hoping that the fact that I got the prompt before enabling the WiFi means that I didn't really have WiFi even though the icon was there.
Woo Hoo!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2018 at 11:05am
I've only ever seen the notice come up once, per bootup.
Was the Wifi icon green? Any unit coming back from the factory will be set to defaults, so you will potentially have to reconfigure BT & WiFi.
Here is a network guide, believe it was snipped from the install manual -- which is no longer available publicly.
https://www.dropbox.com/s/xazbm4x15vfhsol/IFD540_NetworkingSetup.pdf?dl=1
Edited by oskrypuch - 15 Jul 2018 at 11:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kentucky Captain Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2018 at 2:28am
I don't recall if it was green but both icons were there in the upper right corner.
Thanks for the manual.  I'm thinking about setting the IFD540 as a client to facilitate using it in conjuction with Foreflight.  I really wish they would change the software so that the Stratus II could be a client on the network so that I could let my IFD be the WAP.
You are the Manual King!  Now, would you happen to have a manual for the Aspen EFD1000 Pro to calibrate the AOA?  Can't find one anywhere.
Woo Hoo!!!
