  New Posts New Posts RSS Feed - Missing waypoint in KWHP RNAV (GPS)-C Navdata
eallevato View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eallevato Quote  Post ReplyReply Direct Link To This Post Topic: Missing waypoint in KWHP RNAV (GPS)-C Navdata
    Posted: 25 Jun 2018 at 12:15am
Hi
It seems that the "5.6NM to RW12" waypoint in the KWHP RNAV (GPS)-C approach is missing from the Jepp navdata.  I have the latest cycle (1807).
Here is the plate:
When I use the IFD100 app to create a flight plan and insert the procedure, the route does not show the "5.6 NM to RW12" waypoint.  I created a user defined waypoint, however it does not show up as an option when I try to insert it between NAFFU and RW12.
Here is the picture of the missing waypoint in the procedure:
Questions:
1) Is the missing waypoint a bug from Jepp?
2) Can I not insert a user defined waypoint in a defined RNAV procedure section in the flight plan?
Thanks in advance
Gene
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2018 at 8:12am
1. That waypoint is not in the database.  I'll check with Jepp to find out why.
2. Correct, you cannot insert a waypoint within an approach.
Edited by AviSteve - 25 Jun 2018 at 8:13am
This page was generated in 0.250 seconds.
