  New Posts New Posts RSS Feed - Edit Frequencies
Edit Frequencies
rjevansuk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjevansuk Quote  Post ReplyReply Direct Link To This Post Topic: Edit Frequencies
    Posted: 23 May 2018 at 12:23pm
Hi, I'm a newbie here, we've just had the 540 installed on our plane and still getting to grips with it.
Since the introduction of 8.33 here in the UK, airfield frequencies are changing on a weekly basis. I haven't found a way to edit airfield frequencies, is this possible?
Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 1:18pm
The frequencies would be pulled from the navdata I expect. Should update on its own, in a bit. There is no way to do that manually.
But, you can preset some 16 frequencies in your "preset" list. That might do the trick for you. I have a button wired on the yoke to run through them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2018 at 4:06pm
I think there is a setup on the maintenance page to enable 8.33 channeling.  make sure that is properly set up.
