  New Posts New Posts RSS Feed - Autopilot not flying courseline on approach
Cruiser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cruiser Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2018 at 9:46am
snip....
In the problem I was having with the deviation at a one mile final, the Aspen was in GPSS mode, the autopilot was in HD mode, and there was no fixes or transitions at that point.  With the Aspen off of GPSS mode, the autopilot in HI TRK mode inside the IAF, the approach was right on the numbers.
[/QUOTE]
I still don't understand what was loaded in the IFD? On the FMS page you can see the route that is loaded and the active segment as you move along your course. What was the next waypoint (active) you were steering to?
On the S-TEC System 30 the HD mode will follow the heading bug on your HSI/DG.
Switching modes to LO is the same as going from HDG to NAV on other autopilots.
Switching modes to HI is the same as going from NAV to APR on other autopilots.
Both LO and HI switch the source of signal to the navigation unit supplying the course data.
HD mode switches the source data to the heading bug.
Bob H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 1:06am
This is an interesting discussion on how systems interface and how they should be used to fly an approach, especially precision approaches.  For my own understanding and learning, I’ve summarized some of the information from this thread combined with my own thoughts of how things work.  Please let me know if there is any disagreement.
1.       The IFD never knows what state the autopilot is in, i.e. HDG, GPSS, NAV, APPR, HI, LO, etc.
2.       GPSS only functions when the autopilot is in HDG mode.  If HDG mode is not active, then it makes no difference what state GPSS is in.  Therefore, if the autopilot is in HI TRK mode, turning off GPSS will have no effect on anything.
3.       Nothing external to the IFD will affect or change its CDI sensitivity.
4.       The IFD GPSS can only output enroute CDI sensitivity.
5.       A coupled precision approach should only be flown in APPR (HI TRK) mode inside the FAF.
Any corrections?
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulr Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 7:45am
I'm a little confused by #2. I would think the AP will follow whatever course deviation signal it gets. I know that when my AP is in HDG mode, it's getting steering data from CDI 1-- which is driven by the IFD. Whatever nav source the IFD uses is reflected on CDI 1, and thus passed to the AP. If I change the AP to another mode (say LOC), it's still going to follow the deflection on the CDI, wherever it comes from, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HenryM Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 8:14am
In HD mode, my STEC-30 AP follows whatever heading error is provided by the Heading system. This signal can come from a Directional Gyro with a heading bug, or it can come from a GPSS system. The CDI is not the source of the error signal.
The CDI is the source of the error signal that tells the AP to turn when the STEC-30 is in TrkLo (NAV) or in TrkHi (APPR) modes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 8:45am
That is how it works in my setup as well.  Here is a modified diagram from Page 1 of this thread.  When the AP is not in HDG mode, the HDG/GPSS signal does nothing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 8:48am
Quote 4.       The IFD GPSS can only output enroute CDI sensitivity.
I understand your intent with the statement, but perhaps it is a bit misleading -- using the term GPSS (vice GPS course deviation, the magenta line). There is of course no GPSS facility within the IFD.
The other comment, the GPS course deviation actually can/will change from enroute, to terminal, to approach sensitivity, both LNAV & APV, as the situation dictates.
Edited by oskrypuch - 22 May 2018 at 10:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob H Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 9:17am
I understand your intent with the statement, but perhaps it si a bit misleading -- using the term GPSS (vice GPS course deviation, the magenta line). There is of course no GPSS facility within the IFD.
Yes.  Thanks for precision with my wording to avoid confusion.  If I may steal some of your wording, how is this for #4?
4. The IFD output used by the GPSS module only outputs enroute sensitivity.  IFD Course Deviation output does change from enroute, to terminal, to approach sensitivity, both LNAV & APV, as the situation dictates.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2018 at 10:35am
Looks perfect to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kentucky Captain Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 2:56am
Was the heading bug set to the actual course you were flying? As Cruiser suggests, maybe the Aspen is switching the heading source for some reason.
If you are in HiTrk mode, I’m not sure you need to switch GPSS off.
In testing I set the heading bug something other than the final approach course so that I could differentiate between the autopilot following the approach or the heading bug.
The Avidyne guy told me that I could problably get away with leaving the GPSS switch on but there was a caveat that I can't recall at the moment.
I flew last week and shot two GPS and one ILS and something was either definitely not configured right or I have other problems because as soon as I switched to HI TRK and turned off GPSS, the airplane became possessed and left the final for someplace that I didn't want to follow along to.
I'm hoping it was just fat fingered me.
I will definitely try to see the results of leaving the GPSS on.
Woo Hoo!!!
