  New Posts New Posts RSS Feed - Data Update Issues
Data Update Issues
AviTJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviTJ Quote  Post ReplyReply Direct Link To This Post Topic: Data Update Issues
    Posted: 06 Mar 2018 at 12:16pm
10.2.1 did change some file storage locations.  Make sure you're running the latest version of your JDM.  I'm notorious for "skipping" updates, but they do matter when software revisions are released.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 5:34pm
I was just curious if it showed up in 10.2.1. I never had any problem in 10.2. Call Avidyne support, they are great over the phone with things like this.
dstrembicke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dstrembicke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 11:26am
10.2. Is it a known issue in one or the other?
"Quidvis Recte Factum Quamvis Humile Praeclarum"
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 10:38am
What software are you running? 10.2 or 10.2.1?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dstrembicke Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2018 at 10:25am
I'm having an issue where I go through the Charts/Nav/Obstacles procedure. The unit resets and the all are good for that flight...
 BUT then on the next power-up the data is gone and needs to be updated again. Last time it took about 3-4x of this to finally see the data stick. I'm into another update and its doing the same thing.
Any thoughts?
This page was generated in 0.080 seconds.
