  New Posts New Posts RSS Feed - setting up WiFi (10.2.1)
 Post Reply Post Reply Page  <123
mfb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mfb Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 8:43am
To generate the banana, the IFD needs:
  • groundspeed, gets it from the GPS
  • vertical speed, if no real source, it uses GPS
  • altitude, if no real source, it uses GPS
  • target, from the flight plan
There's nothing out of the ordinary that is needed for the computation.  I really need other guys that don't see it on the IFD100 to post configuration/installation details so we can see if there's a common thread.
Can the banana get its target altitude from the altitude pre-select in an Aspen PFD?
Do you have to have a crossing (target) altitude programmed into your flight plan in order to see a banana?
Mike
Edited by mfb - 07 Jul 2018 at 8:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2018 at 5:48pm
Mike
Yes, the altitude target that drives the banana is the next altitude constraint on or after the active leg.
In R9, we would use the preselect altitude to drive the banana.  When we converted R9 to the IFD series, we didn't have reliable access to an altitude preselect so we took out the banana.  When we put it back in for the IFDs, we based it instead on the next altitude constraint on or after the active leg.
ChainSaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChainSaw Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2018 at 5:31pm
which WiFi encryption protocol does the ifd440 WiFi use? WPA, WEP, or WPA2, other??? I believe this is going to be one of the final puzzle pieces to getting the ifd440 to connect wirelessly to a third party app on a Droid device such as Flight Plan GO. I get the ifd440 to connect for about the first 25 seconds then the Flight Plan GO app does not receive further updates from the ifd440.
Edited by ChainSaw - 29 Jul 2018 at 9:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2018 at 9:59am
Originally posted by ChainSaw ChainSaw wrote:
which WiFi encryption protocol does the ifd440 WiFi use? WPA, WEP, or WPA2, other??? I believe this is going to be one of the final puzzle pieces to getting the ifd440 to connect wirelessly to a third party app on a Droid device such as Flight Plan GO. I get there ifd440 to connect for about three first 25 seconds then the Flight Plan GO app does not received further updates from the ifd440.
WPA
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 10:16am
I went back to re-read the networking setup and that link seems to have been removed. Can it be reposted
I realize that none of this helps you get documentation regarding the network setup.  Frankly, it's silly that the documentation is currently in the IM but the IM is not readily available.  We plan to address the whole situation in 10.3.  Specifically, we plan to make the network setup easier and more robust and also put the documentation in the PG.  In the meantime, here is a section of some documentation that provides networking setup instructions.
NetworkingSetup.pdf>>>>
Edited by teeth6 - 12 Aug 2018 at 10:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSteve Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2018 at 10:05pm
Not sure where that went, but I just reposted it.
