Release 10.2.1 Available |
Post Reply | Page <123 |
AviTJ
Newbie Joined: 09 Feb 2018 Location: Melbourne, FL Status: Offline Points: 42 |
Brent, I'm not sure who he spoke with. We are split up into regions, so that may be what he's getting at. I can get him access to the download and SB. Have him email me at tjsutton@avidyne.com I'll get him setup.
compasst
Senior Member Joined: 22 Feb 2015 Location: Akron, OH Status: Offline Points: 169 |
Can we please have a posting of the version 13 installation manual for 10.2.1?
HenryM
601-00182-034 SERVICE BULLETIN, IFD5XX-4XX SERIES UPGRADE TO 10.2.1.pdf is included in the zip file with the 10.2.1 upgrade files. It includes the instructions for installing the update as well as a form to fill out when done.
compasst
My question relates to the entire installation manual for the IFD, not the instructions for the software update. There are things that change in the instruction manual, such as the WiFi setup, that we users need to have in hand so we can be informed before we try to make user-configurable features such as WiFi and Bluetooth work. And, it is nice to have the manual handy when one makes a query of an installer who might not have the latest version available, such as when integrating G5 electronic instruments that depend on many settings that are only contained in the installation manual. If the G5 installer is not an Avidyne dealer, he has no access to the installation manual that is currently posted only on the dealer site. Incidentally, the early versions of this manual were on the documents site of Avidyne and were not restricted access.
Are you sure that a new IM has been released for 10.2.1 and moved to restricted access? I suspect that there is just the service bulletin for the upgrade, but not (yet) an updated IM.
My recollection is that the IM was publicly available in the downloads section because I always downloaded it when a new one came out, but it definitely has disappeared. I don't know why the SB's aren't also publicly available. They can't be used without the new software, and that can be restricted to Avidyne approved avionics shops. Both the IM and SB contain important information for owner/operators when planning panel changes (e.g. adding or changing external interfaced equipment) and trouble-shooting issues before paying an avionics shop to do work.
94S
The r13 version of the IM that pertains to 10.2.1 does exist. I've seen it. I don't understand why it's not publicly available, at least to registered owners if not everyone. It would be very helpful in planning panel upgrades, and even in deciding to buy an IFD or not, to have access to the IM so that a buyer can know (for those that want to know) what the shop knows and be able to speak intelligently with them. I like to be an informed buyer and owner.
Avidyne, why the change?
bobcain
Newbie Joined: 26 Aug 2010 Location: 7K8 Status: Offline Points: 37 |
I will add to the voices that would like the updated IM. These details are important for us that tend to not work with a shop so much as have a A&P/IA look over our shoulder.
jimmyz80
Groupie Joined: 24 Jul 2016 Location: Folsom, CA Status: Offline Points: 86 |
I met up with an A&P friend of mine today, and we went through the 10.2.1 installation procedure on my 440/540 units. Everything went well, and I'd say it only took 30-40min per unit, coming from 10.2.0. The only sticking point for us was that the Service Bulletin requires the installer to do a post-install check based on the IFD Installation Guide version 10 or later. My googling around only turned up version 9.
I put a call into to Avidyne tech support and TJ was awesome enough to help us get our hands on the latest copy of the document. So far it looks like everything is functional as before, and I'm looking forward to doing some flying with the new version later this week. Big thanks to the team!
Yes, there are three or four values that have CHANGED from the prior version. If using the old version, they will apparently not match in the conformity test. But, they actually do.
George
So why the secret IM. I received the update 10.2.1 and it went fine.
I'm am A&P and have done all the releases. I see the IM as an integral part of the install. I wasn't given access to the new IM. I suppose it just worked out.
George
AviTJ
Shoot us an email to techsupport@avidyne.com
We can send you the IM if you need it.
DavidBunin
I will be as polite as possible and simply say that I am very unhappy. This change in the behavior of the avionics was/is a real surprise. I do not recall ever before losing an expected safety feature in an "upgrade". Also, I have yet to see a real reply from Avidyne stating that the CAS logic and messaging remains the same. Will I still get "traffic 12 o'clock high" for example? Honestly, this is stopping me from doing the software update right now. |
dmtidler
The CAS logic and messaging appears to be the same...just no “Traffic” aural. I still get the full caution (yellow) CAS message including relative o’clock position, distance, and high/low. I’m running sw 10.2.1.0 with a SkyTrax100 (RS232 for both traffic and weather).
If “Traffic” will not be specifically announced, I think it would be great to have a user specific optional caution distinct aural tone to bring any IFD generated caution CAS message to the pilot’s immediate attention. |
Ibraham
Senior Member Joined: 21 May 2016 Location: KHWO Status: Offline Points: 356 |
The Skytrax 100 was built by Navworx before they went out of business, which is the reason Avidyne can't update the software on the MLB/Skytrax 100. That is a big failure on the part of Avidyne. The Garmin GTX 345 has aural alerts including position and altitude. I wish it was fully compatible (or future compatible) with the IFD 440 and EX5000 MFD, otherwise I would dump the AXP340 and Skytrax100 and install the GTX 345 (one less antenna and dual link ADS-B in) The AXP340 is manufactured by TRIG avionics. |
Cruiser
can someone share the correct configuration between the Garmin GTX 345 and the Avidyne IFD 540 for TRAFFIC over the ARINC 429 line? I had traffic over this connection with version 10.2.0 after the upgrade to 10.2.1.0 I no longer get TRAFFIC. The configuration settings were not changed. |
Ibraham
On the RS-232 Channel Input and Channel Output
Capstone Trfc+Wx: Garmin GTX 345 and other 3rd party compatible ADS-B traffic and weather devices. |
Cruiser
still looking for some help on the traffic configuration.
My IFD 540 is showing TFC with a red circle w/slash thru it in the upper center of the screen. IFD 540 ARINC 429 IN is set to GDL 88 Traffic GTX 345 ARINC 429 OUT is set to TRAFFIC This configuration worked BEFORE the 10.2.1.0 upgrade. |
Admin Group Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2139 |
Here are some things from engineering to check. If those don't pan out, you should consult either with tech support or your shop about that configuration.
Ibraham
Will the Freeflight ADS-B in that is being promoted by Avidyne have the TSO to allow the IFD 440 the option for aural traffic alerts? Thanks |
The Freeflight unit does not provide aural traffic alerts.
Ibraham
Steve The Skytrax 100 we have installed is providing traffic information to the IFD 440, with revision 10.2 we have been getting aural traffic alerts that were removed by rev 10.2.1 due to TSO as was reported by Avidyne. With the Freeflight unit that is now being promoted by Avidyne, will the IFD 440 rev 10.2.1 provide aural traffic alerts for TIS-B traffic from the Freeflight unit as described in the IFD 440 Pilot Guide rev 10.2.1 PAGE 3-35, or is the info in the pilot guide incorrect? When integrated with an optional traffic system (e.g. TAS, TIS, TCAS, TIS-B), the IFD will display traffic information for sensed aircraft and provide aural and visual alerting for traffic considered a threat
Depending upon your installation, the pilot guide could be incorrect. If your traffic system generates aural alerts and the audio output from the traffic system is wired into the audio system, you will get aural traffic alerts. Otherwise, you will not. I'll take the action to clarify the pilots guide.
Ibraham
That is totally unacceptable, the fact that Avidyne does not have a traffic alert system based on TIS-B. Yet they advertise total ADS-B solutions. that is a total fail on the Avidyne's part.
We invested a large sum of money in Avidyne avionics based on the information available at the time indicating aural traffic alerts on the IFD 440, then Avidyne removed that essential function.
What's the use of a traffic system with no aural alerts. |
Cruiser
I turned OFF the RS-232 INPUTs for weather and this seems to have solved the traffic problem. |
