  New Posts New Posts RSS Feed - NavData database for Simulator
skitheo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Topic: NavData database for Simulator
    Posted: 03 Dec 2017 at 12:39am
When I try to update the NavData database of the simulator from the same USB stick I used for the actual hardware, I get a "Data license count exceeded" error.
Is another subscription from Jepp required to update the simulator database?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 9:30am
You don't use the USB stick method for database updates in the either the simulator or the IFD100. It downloads directly into the program. Just go the database updates page, and go from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skitheo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 4:34pm
On the Windows simulator, there's a Maintenance mode that simulates the screens with database update pages, if you have a USB stick plugged in. If there's no USB, then it doesn't show that you can update anything in Maintenance Mode.
In the regular IFD540 simulator mode, there is no "update" button in the Aux->Sys -> Status: Databases like there is in the real IFD540.
What am I missing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2017 at 4:48pm
Sorry, thought you were using the iThingy simulator.
Don't think you can update the Windows simulator databases.
Edited by oskrypuch - 03 Dec 2017 at 5:00pm
