  New Posts New Posts RSS Feed - Manual CDI scale change
OliverBucher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OliverBucher Quote  Post ReplyReply Direct Link To This Post Topic: Manual CDI scale change
    Posted: 15 Aug 2017 at 5:13pm
Hello,
is it possible like on the G530 to change manual the CDI scale from Enroute to Terminal or Approach?
I have found nothing in the manual.
My software version is 10.2.0.0.
When I have a User Waypoint and it is labeled as an Airport, will in this case the IFD change from Enroute to Terminal scale, when I approach the waypoint ( in this case my home airbase which is a German glider airfield => User-Waypoint).
Greetings
Oliver
Oliver Bucher
Plane: DA40-180
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 9:51am
CDI scaling can not be manually controlled.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 11:10am
It is not clear to me if the second part of his post is a statement or a question.
Will the IFD treat a user-waypoint-airport like any other destination, and auto-scale to the TERM mode?
Post Options Post Options   Thanks (0) Thanks(0)   Quote OliverBucher Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 2:50pm
The second part was also a question.
Sorry my english is not the best :-)
Oliver
Oliver Bucher
Plane: DA40-180
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2017 at 8:59am
No.  The ability to designate a user waypoint as an airport was implemented for the sole purpose of supporting the TAWS function.  That's why you have to enter a field elevation as part of the definition.
