  New Posts New Posts RSS Feed - Reset of COM Frequencies
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Topic: Reset of COM Frequencies
    Posted: 26 Jun 2017 at 1:34pm
Check that you have the same Mhz COM spacing on both user profiles. I've see this reset to 118.000 behavior when switching between a user with 8 Mhz COM spacing and one with 25 Mhz COM spacing. This also happens when you change the COM spacing for a user.
I set all five user profiles to the same COM spacing for that very reason (both IFD 540 and IFD100).
KIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KIM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2017 at 10:44am
When I change the the user profile in flight (e.g. from VFR to IFR), the Com Frequencies will be changed to 118.000. I don't know if this is intentional, but I would prefer to keep the frequencies.
Klaus
This page was generated in 0.081 seconds.
