  New Posts New Posts RSS Feed - IFD440 swapping active/standby freqs on its own
vcollazo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vcollazo Quote  Post ReplyReply Direct Link To This Post Topic: IFD440 swapping active/standby freqs on its own
    Posted: 23 Jun 2017 at 4:23pm
3 timesover 2 flights on separate days into/out of KALB IFD changed my standby freq into the active on its own. IFD 100 was not in use. Has anyone else ever seen this? Logs have been downloaded and sen to Avidyne. In looking at events log, when the freq change was intentional the keystroke sequence was L6L press and release, but unintentional was L3L press L6L press L6L release L3L release. I've figured out L6L is the freq swap line select key, but have no idea what L3L could be. In 7 months of using the IFD I have never seen this before.
vcollazo
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 5:26pm
Do you have a single unit, or two IFDs?
Was your iPad connected, even if the IFD100 was not running?
Edited by oskrypuch - 23 Jun 2017 at 5:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote vcollazo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2017 at 10:07pm
It is single unit. Can't remember if at that time Ipad was connected to the 440 or to the stratus. It was probably connected to Stratus for Nexrad, but can't be sure.
vcollazo
bobcain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobcain Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 5:12pm
I haven't looked for sure, but there is probably a remote input to switch them. Could this be an errant wire or contact unknown to you? Just a thought....
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2017 at 5:21pm
Yes, there is a remote freq flip input, as I have it wired in my plane.
This page was generated in 0.135 seconds.
