  New Posts New Posts RSS Feed - NAV Data effective dates
arkvet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arkvet Quote  Post ReplyReply Direct Link To This Post Topic: NAV Data effective dates
    Posted: 19 Jun 2017 at 9:47am
This question may have been asked and answered before but I'm not sure where to find it.  Also, this isn't necessarily specific to the IFD 100 as I'm sure it applies to the IFD's and probably any other IFR gps.  I'm really new to IFR data.
Can someone explain the technicalities surrounding effective dates?
I just downloaded two "cycles" to my jump drive to update my 550 that just came back from the avionics shop.  Jepp allowed me to download both 1706 (current for 3 more days) and 1707 (effective June 22).  When I go to update the 550 is it going to pull both updates and do the switch for me on the 22nd?  Or will I have to manually go from 1706 to 1707 on or after the 22nd?  OR can I go ahead and skip 1706 since 07 has been released?
And for the IFD100 (and trainer applies same way).  On the ipad I updated to 1706 and tried to download 1707 too.  It looks like it dumps one to download the other.
I'm betting the explanation is simple but need to understand it to prevent getting in the plane and having and IFD100 app that won't work because of a different database cycle.
Oh, and while I'm at it (for anyone that knows).  Is it ok to use the same jump drive for IFD data updates that I use from my JPI830 data?  Will either box get mad?
Brent
Brent
PA32-301
IFD550 / AXP322 / SkyTrax100
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 9:59am
The IFD550/540/440 has one database cycle active at a time.  It becomes active when you load it into the device via the USB stick.  So, if you load 1707 3 days early, that is the database the IFD will use (legality aside).  There is no way to store multiple cycles in the IFD.
I hope this helps.
FlyingCOham View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 3:15pm
Virtually all FMSs in "bigger iron" allow you to load two databases sets.  The pilot selects the current one.  This is great especially important when a trip spans across effective dates.  The Avidyne 4/5xx systems only allow one database set at a time.  If you need to switch during a trip, yto be legal you must hold the newer dataset on a memory stick until the changeover date, then load it.  This situation was highlighted to Avidyne management over a year ago with no response.
Jim Patton
Post Options Post Options   Thanks (0) Thanks(0)   Quote arkvet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 3:22pm
Makes sense. Thanks guys.
One follow up.  From a practical stand point (legal issues aside) what are the hypothetical problems with loading the next cycle a day or two early?  Are there changes with the system that coincide with the data cycle date?
Brent
PA32-301
Status: Online
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gring Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 3:29pm
If you have an out of date Navigation database (either an old nav set or a new, not current nav set), you run the risk of not having a waypoint, victor airway, approach, airport, or navaid available to select.
There are no software enhancements, updates, or changes when loading the Nav, Obstacle, Terrain, or Charts databases.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 5:45pm
A slight caveat, many of the changes in any distribution update cycle have already been implemented via NOTAMs.
Edited by FlyingCOham - 19 Jun 2017 at 5:49pm
Jim Patton
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2017 at 6:45pm
The CNX-80 allows two different databases, it had most everything! Neither the G or A current products allow for that.
If I were flying over the 0900z witching hour for the changover, I'd put in the more future database as the better choice of two not perfect choices.
