Foreflight connectivity issues with 10.2 |
Post Reply ![]() |
bwendel ![]() Newbie ![]() Joined: 23 Nov 2016 Location: Ithaca, NY Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jun 2017 at 2:26pm |
After upgrading to 10.2, I can no longer display weather and traffic on my iPad. There's wifi connectivity, because I can push a flight plan from Foreflight to the 540 (cool feature, btw). Ownship display is fine, too. I know the MLB 100 is receiving ADS-B weather and traffic, because it displays on the 540. I'm just not sure why I'm getting "radar not available" at the same time on Foreflight. I know it's not the end of the world, since the 540 display is available, but I kind of prefer the way Foreflight displays precipitation - it's a bit sharper and the colors tend to be a more accurate representation of the actual weather. Any ideas what the glitch may be?
oskrypuch ![]() Senior Member ![]() Joined: 09 Nov 2012 Location: CYFD Status: Offline Points: 2204 |
FF doesn't support pulling TIS & FIS from an IFD, yet.
n7ifr ![]() Senior Member ![]() ![]() Joined: 05 Aug 2013 Location: Phoenix, Az Status: Offline Points: 338 |
If you route your WiFi connection from FF via the 540 "Remote" Hub through your Stratus box... I would think all FF Wx products should be intact. I will check next flight to see if all FF and FlyQ iPad "Stratus-features" remain despite hooking up to 540 via the remote hub. Should be unaffected. Tom W.
Yes, I have my IFD (remote mode) & tablet connected to my Stratux, and it all works. I get ADS-B TIS/FIS from my Stratux to FF, and FF can up/download flightplans and location. But, I think the OP does not have a portable ADS-B IN unit, he is trying to pull the Skytrax data down to FF. * Orest |
Orest, always difficult to choose which thread is most applicable, but: Flew this AM with my Dual 540’s un-synched. 1. Sent a new ForeFlight FP over WiFi (remote) to 540 #1, and got familiar disturbing message that “Routes re-synchronizing… “ with progress from “0% - 100%… followed by total deletion of all Routes!! 2. Tried same with 540#2 (Local WiFi), no issue at all. 3. After restoring Routes from thumb drive to 540#1, entered a manual New FP without issues. 4. Later, in flight, up-synched a New FP via ForeFlight using WiFi (remote) to 540#1, this time, No Issues. 5. Then, in flight, up-synched a New FP via ForeFlight using WiFi (local) to 540#2, and No Issues. My Conclusions: 1. Deletion of Routes (sometimes User Wpts) seems related to the Synchronizing process, in general, not necessarily between cross-synching 540’s, but any synch. from an external device from - iPad App, or other 540!! Obviously this is very concerning - can you please make engineering aware ASAP… Does this sound like I'm having a 540 hardware, or Software issue with v10.2? Help. Tom Wolf
Edited by n7ifr - 19 Jun 2017 at 3:03pm |
I have not personally seen this disturbing behaviour, but I only have one unit, and two installed units may be a necessary condition regardless of what actually triggers it.
I think I read here that the issue has been duplicated, and that 10.2.1 may address this (?), but I may be wrong as I wasn't paying close attention to it. * Orest |
arkvet ![]() Groupie ![]() ![]() Joined: 12 May 2017 Location: Arkansas Status: Offline Points: 78 |
Tried foreflight connection with IFD 550 for first time yesterday. iPad connected to IFD wireless network no problem. New button at top of foreflight allowed me to pull flight plan from IFD. That worked perfectly.
I was under the impression that the last foreflight update allowed biderictional flight plan transfer? Does that FF to IFD transfer need to be initiated via the IFD? To be honest though this is mainly to satistfy my curiousity. When I was flying with my old GNS530w the idea of FF pushing a flight plan was a dream. I actually find flight plan entry into the IFD to be as easy if not easier. |
Brent
PA32-301 IFD550 / AXP322 / SkyTrax100 |
Yes, I can upload as well, but it pushes it to the route page, does not change the active route (which is good). In the FF 9.13 dialog on the FF MAP page I have a choice of download, or upload. And, yes, that is exactly my experience too. Flight plan upload/download is cool, but not that important with the IFD, as it is lightning fast to enter on screen. It also reinforces the flight plan in your mind, and double checks it as you build it graphically. I use the download occasionally , if there is an enroute rerouting, I have the IFD push the new plan to the tablet. * Orest |
George ![]() Groupie ![]() ![]() Joined: 08 Apr 2014 Location: 66Y Status: Offline Points: 81 |
I also have the IFD 550. I can connect thru the local connection, but not thru the remote. Tech Support says there is a problem and a fix is coming. Can you confirm
you can connect by way of Stratus or other remote hubs? |
Yes, confirmed. BUT occasionally (1 in 10 flights) the IFD just doesn't connect - so I may just be seeing this bug intermittently. * Orest Edited by oskrypuch - 20 Jun 2017 at 11:10am |
Thanks for the reply . My IFD 550 is a solid problem.
There is suppose to be a fix in 10.2.1, but no proposed release date.
Thanks, Orest. That's exactly the problem - I don't have a Stratus and was trying to pull ADS-B data from the MLB-100 to ForeFlight. Glad to know it's not supported, and not my screwing up the configuration somehow.
psimpson ![]() Groupie ![]() Joined: 23 Oct 2015 Location: Hays KS Status: Offline Points: 52 |
Is there anywhere on the IFD that shows it connected to the Stratus or just in Devices in FF?
Not that I know, although you might be able to pull that out of the logs. Easiest way to tell, is use a free app like Fing. Available in android & iOS. * Orest |
Post Reply ![]() |
