  New Posts New Posts RSS Feed - Base Map details
Base Map details
guenter_ms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote guenter_ms Quote  Post ReplyReply Direct Link To This Post Topic: Base Map details
    Posted: 28 May 2017 at 6:55am
Hi,
the removed Garmin 530 showed:
-cities
-city name
-interstates
-interstate names
-river names
and could be perfect setup for declutter in the "setup Map" Menu.
All those informations are not visible on the IFD540, except the interstates, which are visible in the US, not in Europe as with the Garmin before.
Is there any error in the software or database? Both databases (Garmin&Avidyne) are coming from Jeppesen, and the data should be available.
If it "works as designed" on the IFD540, pls put it on the feature list. Then anyone can answer the questions of the passengers "where are we at this moment?" as we could before on the old Garmin.
Best regards
guenni
MarkZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarkZ Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 8:27am
Tell em you're over Centerville, oh yeah, that's Clearlake. Problem solved! :-)
Post Options Post Options   Thanks (1) Thanks(1)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 8:55am
Obviously, you are right on the magenta line.
George P View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote George P Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 10:04am
That is what your Ipad is for.
KIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KIM Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2017 at 8:26am
Originally posted by guenter_ms guenter_ms wrote:
Hi,
-cities
-city name
-interstates
-interstate names
-river names
Best regards
guenni
++1
otherwise, what is  the "Land" declutter for?
Klaus
This page was generated in 0.211 seconds.
