Preferred vertical speed rate / FMS Setup Page |
bradthepilot
Posted: 09 Feb 2017 at 3:05pm |
So I love the TOD callout feature, but the default of 500' fpm is a bit low and I'd like to change it. I see references in the documentation to changing the default on the "FMS Setup Page" but don't see the setting when I go there via AUX->Setup->User Options. I'm clearly looking in the wrong place, but not sure where to find it.
Any suggestions from the community's wisdom? Thanks! Brad |
Brad Benson
RV-6A N164BL |
AviSimpson
You're on the right page and tab. The decent rate selection is under the FMS Setup. Press the LSK until you get to the FMS Setup view (it switches between MAP Setup and FMS Setup).
bradthepilot
Wow, it's like finding a secret room - so cool!
Thanks! -Brad |
Brad Benson
RV-6A N164BL |
AzAv8r
And the response was not "I see no cave here."
(Raise your hand if you know where that came from.) ;) |
bradthepilot
"You are standing at the end of a road before a small brick building." |
Brad Benson
RV-6A N164BL |
What happens if you try to fly to the XYZZY waypoint?
The original text based adventure game for the IBM PC back in 1983ish
bradthepilot
It predates the IBM PC by a fair bit, actually.
Brad Benson
RV-6A N164BL |
I remember playing that on a lineprinter console attached to a PDP-11, in the seventies!
https://en.wikipedia.org/wiki/Colossal_Cave_Adventure
Edited by MysticCobra - 10 Feb 2017 at 2:24pm |
AzAv8r
I remember it from the pre-PC days too. I didn't realize it still had a life! I might have to download a copy to reminisce.
Paul
I used to have a copy of the source code. I worked in the building where the PDP-10 (later called DECsystem 10) was manufactured. I was a software guy - worked on the FORTRAN compiler and run time library and linker, among other things.
This is getting way off topic, but I will say that the any of the IFDs has more processor power and memory than the biggest PDP-10 mainframe. |
Available for your android phone or tablet!
https://play.google.com/store/apps/details?id=com.ecsoftwareconsulting.adventure430&hl=en A full play through on youtube (spoiler alert), appears to be on a DOS machine: https://www.youtube.com/watch?v=O3etkSoHrR8 * Orest Edited by oskrypuch - 11 Feb 2017 at 12:12am |
