Caution Underspeed |
jimmyz80
Groupie Joined: 24 Jul 2016 Location: Folsom, CA Status: Offline Points: 86 |
Posted: 28 Jan 2017 at 6:38pm |
Ever since i had my DFC90 installed, I've been getting super annoying "Caution, Underspeed" warnings on landing rollout. So you're rolling down the runway listening for exit instructions from the tower, and the DFC is bitching and complaining that I'm going too slow. :)
I assume this doesn't happen to everyone, or it would be a much bigger deal. Any ideas as to why this would be happening?
Melohn
Senior Member Joined: 11 Dec 2013 Location: PHNL Status: Offline Points: 124 |
Assuming you have a Cirrus, you are hearing this because your flap switch is not connected to the DFC90, so it assumes that you are flying with flaps up.
You have two choices; have the flap switch connected to the DFC90, or always use the autopilot disconnect when operating at speeds below ~80 knots; you won't hear the caution when the autopilot is in AP READY state. |
jimmyz80
The flap switch is properly connected, since I get the appropriate flap overspeed warnings.
jimmyz80
Bumping this back to the top since I had forgotten about it, but the warnings still continue. The flap switch is definitely connected to the DFC90 since I get flap overspeed warnings as appropriate. But when landing, even with the AP and FD fully disengaged, I still get underspeed warnings on roll-out. It's super duper annoying since it's inevitably talking over the top of a tower controller trying to give me runway exit instructions.
Any ideas why it would be doing this?
Ibraham
Do you retract the flaps on rollout? try to keep the flaps extended until you exit the runway to see if you still get the alert.
On some configurations, full flaps condition suppresses the "underspeed" alert. You could look at the DFC90 Pilot Guide Section 6 "Limitations and Performance" table for your specific configuration.
jimmyz80
I tried that test as well on recent flights, and I get the warning regardless of whether I leave in 100% flaps or retract them while rolling. I see some notes about the warnings being suppressed when "near idle" but that's not quantified in any way. Many times I still have a little taxi power re-applied on the ground to clear the runway quickly at large airports. I have no way to know if that still qualifies as "near idle".
Ibraham
See this SIL from Avidyne (page 6), it addresses Underspeed Alerting in DFC90 and SIU-Equipped Cirrus Aircraft
https://www.avidyne.com/files/downloads/606-00006-002.pdf SR22 S/N:1663 and on have DAU (Cirrus SR22 S/N 435-1662 have SIU)
Melohn
I read the SIL, but it didn’t seem clear to me what happens in an SIU aircraft with R2 software and latest PFD software that does NOT have the flap modification. It would seem as though the logic should say, no flap input, no Manifold Pressure input, no alerting, but it wasn’t clear to me that’s the case. I happen to have that configuration, but am still running R1, which does not provide the warnings unless you leave the AP in FD mode. I’m quite happy with this, but fear someday I’ll need to send in my DFC90 and it will come back with new software.
jimmyz80
My aircraft is DAU equipped, so this SIL doesn't apply.
dopolinsky
Newbie Joined: 11 Mar 2019 Location: ME, USA Status: Offline Points: 11 |
Jimmyz, I have been working on this problem in my DAU equipped 2007 SR 20 for a year and half. After checking flap wiring and all avionics configurations my attention is now turned to the Manifold Pressure.
According to Avidyne tech support Caution Underspeed aural alert that we are hearing during landing should be inhibited by a combination of the Flaps 100 and a manifold pressure below 13.5" I have been looking at my MP and they are about 14-15 when I close the throttle. Our family of engines should have the MP at about 12" when idling with a closed throttle. This can obviously be caused by a bad sensor or an intake leak. I haven't found my intake leak yet but I just started looking. You can sometimes detect it by closing the throttle to 20" or less inches at 5000 feet or so. If the leak is near one cylinder it will run leaner and have a lower EGT than other cylinders. The number 13.5" is not in the pilot manual for DFC 90 and is not well publicized. Owners wit this issue naturally look to avionics shops to resolve it and Avionics techs gravitate toward the electronics and away form the engine manifolds which makes this additionally chaleging to work on.
Edited by dopolinsky - 22 Mar 2019 at 8:39pm |
jimmyz80
Thanks! I'll have to keep an eye on my manifold pressure when I get the warning.
Aerochip
Groupie Joined: 24 Sep 2019 Location: Utah Status: Offline Points: 46 |
Having the same issue on a SR22 with DFC90 that I fly. Caution Underspeed aural alerts on the runway with the AP and FD disconnected. It’s distracting when you can’t hear turnoff instructions.
MP is definitely below 10” and it only happens after touchdown.
Were you able to resolve this issue and what was the solution? |
dopolinsky
I have not resolved my issue due to problems with fuel pump adjustments at low idle and continued inability to get MP low.
The older SIU (not DIU) Cirrus has a different software fix for the PFD software that inhibits "Caution Underspeed" when flaps are 100%. You need that PFD software patch if you have an SIU Cirrus. SIU does not send MP to PFD and AP.
Roger
Newbie Joined: 30 May 2019 Location: Kentucky Status: Offline Points: 35 |
Try turning off flight director and see if that makes it stop saying that.
Aerochip
Figured out my issue on this airplane - I was dumping flaps during the landing roll-out, which was triggering the Caution Underspeed alert. If I wait until turning off and then raise the flaps, I don't get the warning.
Roger
I will try that. My flaps are tied into the airspeed system so maybe that will work!
