  New Posts New Posts RSS Feed - JDM "ver 10.2 or greater"
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: JDM "ver 10.2 or greater"
    Posted: 26 Jan 2017 at 11:46am
So, any issues updating to this navdata drop, on a pre-10.2 (10.1.3) IFD540?
Edited by oskrypuch - 26 Jan 2017 at 11:48am
Thinwing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thinwing Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 12:13pm
I didn't notice any on my first time americas subscription using new jsum sw
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 12:37pm
I had the same question in December when the JDM was updated and SW 10.2 compliant charts were available. I called Jeppesen and was told that the chart downloads were backwards compatible with IFD's using software earlier than SW 10.2.
My IFD540 is using SW version 10.1.2 and I have loaded at least two chart cycles with the new JDM chart format without any issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 12:56pm
I've loaded the previous ones, but this is the first time I've seen that annotation.
Good to know, for sure, that it is not an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 8:41pm
Would be even better if Jeppesen would annotate the files with the actual minimum software version they will work with so customers aren't confused.
Oh, but wait...it's Jeppesen.  They don't care if their customers are confused.  It's pretty much their business model.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 10:26pm
I also have the same warning now, but it is also showing the same warning on the current NavData, which I've already uploaded with no problems.  I don't recall the warning there when I downloaded the current NavData.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jan 2017 at 11:50pm
No, the warning is new, now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmtidler Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2017 at 8:18am
The warning placement might be new; however, the JDM update a few months ago had the same basic message about being for SW 10.2 and newer. I run a copy of JDM on two different computers and saw the message in the JDM upgrade process as well as in the first downloaded charts file at that time.
This prompted me to call Jeppesen regarding the backwards compatibility of their data files before I upgraded JDM on my second computer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pburger Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2017 at 3:06pm
I saw that, too, about 2 weeks ago.  Was a little worried I'd have to scrub an IFR flight, but my 10.1.1 box took the update no problem.
jblodgett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jblodgett Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 11:46am
How come I am always the lucky one?  Nav data would not load for me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2017 at 12:21pm
What exactly happened? Error message, hang?
Problem loading it to the USB key, or onto the IFD?
