  New Posts New Posts RSS Feed - Ifd540 delay in gps lock
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Topic: Ifd540 delay in gps lock
    Posted: 31 Oct 2016 at 3:54pm
I think there might be some confusion because there is no 10.1.4.
I have looped in our Tech Support team and they should be following up with you. Our apologies for the delay in response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 6:08pm
I have not heard about 10.1.4.
compasst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote compasst Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2016 at 5:15pm
I'm running 10.1.4 and experience LONG lock-on delays compared to when I was running 10.1.1. I did not update to either 10.1.2.or 10.1.3 as I did not receive notice that they were available until after I reported a lost signal on 10.1.1 a couple months back. I have also had a nav failure on 10.1.4 and have talked with tech support two weeks ago when I sent in the logs. I've not heard anything back as yet.
docricky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote docricky Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 4:52pm
Updated Sofware, gps lock faster than my GNS430w now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2016 at 8:49am
10.1.3 is for those with GPS lock issues, update to 10.1.3.
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 10:55am
Just to add a data point - I am also running a 540 / 440 combination using 10.1.3 firmware, and it almost never takes more than 2-3 minutes once I wheel the plane out of the hangar for them to find lock.  I have never lost lock on these units in flight.
Edited by AUXAIR - 29 Sep 2016 at 10:57am
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 9:21am
I'm running 10.1.2 and there are times my units (540 and a 440) take five minutes to find lock.  They both lock at the about the same time so I was thinking that's just the way it is.  They have never lost lock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2016 at 9:14am
Get up to the latest firmware, that solves most of the problems.
If it doesn't, download your logs and send them into Tech support, they will see what is going on, and fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote docricky Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2016 at 10:54pm
My ifd540 has trouble finding my gps position on startup, I wait sometimes 10min, already warmed up plane took off and flying before I get a gps position. Sometimes have to reboot 540 twice before I get gps lock.
This is a new phenomena, it never took this long??
Running 10.1 version waiting for software update from dealer
Any ideas?
