  New Posts New Posts RSS Feed - ETA off by AM/PM on PM flights
compasst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote compasst Quote  Post ReplyReply Direct Link To This Post Topic: ETA off by AM/PM on PM flights
    Posted: 25 Aug 2016 at 12:14pm
Sometimes I have seen the ETA at destination showing the wrong AM/PM tag. So far it has always been a PM showing as AM. This is intermittent. A check of settings shows correct local time offset. It has occured in same time zone as aircraft is presently located, and also occurred across time zones. It has happened 3 or 4 times, but nowhere near every time. Times that I've seen it have been when ETA is late evening/night. Never seen a PM/AM swap, ie., PM showing for an AM arrival, nor have I seen it when ETA is prior to 6 PM.
Anybody else see this?
Will this show in the flight log? just thought of that, so I'll download them and check.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2016 at 6:23pm
This is a known bug, and I believe it is fixed in 10.2.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 9:38am
It happens when your arrival time occurs in the next Zulu day. (After midnight in Greenwich.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2016 at 2:06pm
Yup, fixed in 10.2.
