  New Posts New Posts RSS Feed - A few cool installation options shown at Oshkosh
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Topic: A few cool installation options shown at Oshkosh
    Posted: 22 Jul 2016 at 3:08pm
The Avi booth at Oshkosh this year will have a 4-sided center pedestal that showcases some neat installation options.   Included in that pedestal will be:
1.  A real Cessna 172 panel with an IFD550 in the stack driving a landscape mounted IFD100 on an iPad Air that is mounted over the traditional 6-pack.  The iPad mount has no back to it so you can leave your instrument panel untouched, mount the bracket and pop your iPad in/out as you see fit.  That gives you a really affordable glass upgrade to your legacy panel.
2.  A forward fit panel with two rear-mounted iPad mounts in the  traditional PFD and MFD locations, both being driven over WiFi by a single IFD550.
3.  A IFD440 driving a 12" iPad Pro for truly giant glass.
4.  A RV panel showcasing the increased SkyView-IFD integration upgrades we've just completed.
Probably worth checking out if you're near Hangar C.
brou0040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2016 at 9:18pm
Sounds intriguing, do you have any pictures for those who won't make it to OSH this year?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2016 at 8:47am
I'll take and post some on Monday, if Simpson doesn't beat me to the punch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2016 at 9:37am
Forgot to post some pix of the booth.  Here are a few fun ones:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2016 at 9:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2016 at 9:43am
The red-X's in the top two pix are because the IFD550 in the booth didn't have power being applied to the VHF connector, so the VHF freqs weren't being transmitted over WiFi.
Avidyne and Dynon/Advanced Flight Systems both updated our software to increase the integration between the two sets of boxes - for example you can tune the com/nav freqs on the IFD from the Dynon/Advanced Flight Systems boxes now.
The 12" iPad Pro in the bottom show was configured to think it was talking to an IFD410 (the no-VHF version of the IFD440) so that's why no comm freqs are showing up in the top left corner of the iPad in that last shot.
idmpilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote idmpilot Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2016 at 6:46am
If you cover up your six pack which I'll call ai,hsi,asi,tc,altimeter and vsi will the ifd 100/ifd550 relay all that info? From the ifd 550 proposed pilot's manuel,it could easily replace the hsi and ai. But what about the pitot-static info. You could get gps altitude/or gps above ground altitude and vsr instead of vsi. Would you use gps groundspeed? If you have an aspen 1000 could the ifd's recieve and display all the pitot static info?  Thanks
j george
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2016 at 8:14am
For Release 10.2, if the IFD550 has access to air data (e.g. from an Aspen PFD, or Garmin G500, or air data computer, etc), then it passes that air data along to the IFD100 which will display airspeed and altitude tapes.
Post Release 10.2, we'll likely add those tapes to the panel mount IFD as well.
luchetto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote luchetto Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2016 at 8:46am
Steve, will the airspeed tapes be configurable to match the various arcs of the airplane in use?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2016 at 8:48am
Eventually.
We're running out of time to have a means to do that as part of Rel 10.2 but the good news is that since this is only the IFD100 app we're talking about, we'll be in a position to add that quickly post initial release of the app.
n7ifr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2016 at 9:44am
Speaking of GPS Altitude, I am at a loss to find this anywhere in the 540... (just AGL and Minimum Safe Alt - and of course derived from iPad GPS apps).
Can someone direct me to where this data can be displayed in the IFDx40's?
Tom Wolf
Catani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Catani Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2016 at 12:27pm
On IFD: AUX - Setup Tab - Datablock Setup.
Also, IFD440 Pilots guide pg 4-16 (complete with picture showing GPS AGL altitude in top right datablock). Very nice!
Sorry I can't point you to exact page in IFD540 manual, but in IFD440 manual the exact page is in the table of contents: AUX Pages - Setup Tab - Datablock setup.
ddgates View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 9:37am
I believe Tom is looking for straight GPS altitude, not GPS AGL Altitude.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 9:39am
Steve, I realize that the IFD100 driven by, say, an IFD540 won't show AH, but would it too be able to display speed and altitude tapes if air data were available, or will this be restricted to IFD550 as source?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 9:29pm
IFD550 only
ac11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac11 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2016 at 2:33pm
AviJake,
Is there a response to Tom for GPS Altitude? I would further like to see this recorded in flight log.
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 11:31am
GPS altitude is recorded in the Systems datalog.
Post Options Post Options   Thanks (0) Thanks(0)   Quote n7ifr Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2016 at 8:50pm
So, I gather there is no display of GPS MSL altitude available in the 540, just AGL.
Tom Wolf
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2016 at 9:43am
GPS Altitude is displayed on the SYS tab of the AUX page.
ac11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac11 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 2:11pm
AviSimpson,
It appears there is not a one to one update rate between the two logs. Looking at the system log that I have access to, I see gaps of several seconds mid flight. What is the criteria for writing a record to the system log? Can GPS altitude MSL be written to flight log as an enhancement?
Jeff
Edited by ac11 - 03 Oct 2016 at 2:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2016 at 2:57pm
The short answer is the criteria varies depending on the data point.
I'll add the request to the list to see what effort it would take to move the GPS MSL to the flight log.
ac11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac11 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 12:27am
Thanks for the reply AviSimpson. I think this is the first GPS I've come across that didn't have GPS MSL altitude readily available. Having it in the flight log will be a nice improvement, and a data block would be great too. Thanks.
Jeff
FlyingCOham View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FlyingCOham Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2016 at 3:44pm
"and a data block would be great too."
ditto!!!!!!!!!!!
Jim Patton
This page was generated in 0.115 seconds.
