  New Posts New Posts RSS Feed - Origin not in Database
PA20Pacer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Topic: Origin not in Database
    Posted: 01 Jul 2016 at 8:47am
Hello All-
I departed yesterday from an airstrip not in the Jeppesen database. I had created a user waypoint for the airstrip, but my IFD540 would not let me enter that waypoint as the origin by editing the nearby origin airport that the 540 chose.
Does anyone have any thoughts on the proper way to specify an origin not in the Jeppesen database?
Brookeridge Airpark (LL22)
Downers Grove, IL
Jack Seubert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack Seubert Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 10:13am
Bob,
Take a look at page 2-39 in the PG.  It works great.
Jack
Jack Seubert
1964-m20e View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1964-m20e Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 11:43am
I have the same problem.  I let Avidyne know about it and they are supposedly looking into this.  I am fortunate I have a Class B airport 3 miles from my home base so I default to that for my origin for now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 1:20pm
Hi Jack-
Thanks for the suggestion. When I set up the user waypoint, I did use the appropriate naming convention as indicated on page 2-39. The waypoint displays on the map as shown in the lower figure on page 2-39, and I do not get terrain warnings when landing. However, when I was on the ground at that location, my user waypoint did not come up as the origin, and I was unable to edit the origin field to the name of my user waypoint.
It is not a big deal, as one can always just accept the populated origin and then enter direct to the first waypoint on the route, but it seems that there should be a better way.
Downers Grove, IL
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 2:53pm
That is a current restriction, no other way to do that for user defined airports.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 4:31pm
Thanks to John and Orest for pointing out this limitation. It is good to know that I am not missing something simple.
Downers Grove, IL
DH82FLYER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DH82FLYER Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2016 at 10:58pm
Hi All,
This issue has been discussed before and the following is part of Steve Jacobson's reply...
"This is per design. The only advantage you get from entering an origin is that you can enter a departure. You can also enter a runway, but that's only significant if there's a departure. So if you create a user waypoint representing your airfield and then use that as the first leg in your flight plan, the effect is nearly the same. Yes, activating that flight plan will cause a direct to that fix, but all you have to do is activate the second leg (or go direct-to it) and you're all set."
In other words, when building a route from a User Waypoint, you need to nominate it as a "Waypoint" rather than an "Origin" from the dropdown list.
Thomas
Edited by DH82FLYER - 02 Jul 2016 at 2:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PA20Pacer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2016 at 12:06am
Hi Thomas-
I can certainly live with that procedure. Thanks for pointing out Steve's previous response.
Downers Grove, IL
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1964-m20e Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2016 at 3:10pm
Well the good news is the latest database update my home airport LS40 is now in the database and can be selected as the origin for the flight plan.  Now I have to edit my flight plants to remove the surrogate origin waypoint.
