EVS Camera for 10.2 |
Senior Member Joined: 30 Dec 2011 Location: Kingston, NY Status: Offline Points: 723 |
Posted: 12 Apr 2016 at 12:48pm |
I thought I'd check into the feasibility of installing an Enhanced Visibility System (EVS) FLIR type camera on my airplane to connect to an IFD540/550 with 10.2. If found that Astronics Max Viz has several certified camera systems that look to work with the IFDs, with one the OEM option on a Cirrus.
Astronics Max-Viz has several models running from 9k to 25k for the camera. Here is a link to the website: www.max-viz.com Some things I learned: - They feel the 320x240 resolution is sufficient for a smaller screen like the IFD540 - It may not work well through fog or heavy clouds - They have heaters to handle icing conditions - The more expensive one has a zoom option (using a manual on/off switch - The model 600 blends a camera with a light detector so it can show runway lights
Edited by Gring - 12 Apr 2016 at 12:52pm |
I am researching exactly the same thing.
We have quite a bit of experience using the MaxViz camera. It works great but as you note, it's not $ cheap.
We will support any RS-170 protocol camera. That does include a bunch of FLIR cameras as well as a lot of inexpensive color "lipstick" cameras that use NTSC output format. |
