  New Posts New Posts RSS Feed - Feature Request: add a VNav path indicator
Post Options Post Options   Thanks (1) Thanks(1)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Topic: Feature Request: add a VNav path indicator
    Posted: 03 Apr 2016 at 12:36pm
This is entirely akin to a glideslope/glidepath indicator, but would instead reflect your relative position as compared to your desired descent (or ascent) profile as reflected in the specified vertical constrains and your specified default VSR.
Borrowing the graphic from the FIX page request, note the white linear graphic with the magenta diamond on the right side of the graphic. This is depicting the aircraft "on" VNav path. Besides floating the diamond up/down as this changes, you could also display the number of feet high/low, in comparison to the computed vertical path.
This would be a very cool "big boy" feature to add to the IFDs, in concert of course with the Boeing Banana.
Edited by oskrypuch - 03 Apr 2016 at 12:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:20pm
I'll put it on the list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2016 at 9:46pm
Great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2017 at 5:41pm
This is closely related to VSR and a Boeing Banana, a good time to implement it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2017 at 9:18am
I appreciate the campaigning for the feature. Like I said before, it has our interest but I won't say when or how quite yet it would/could be implemented.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2022 at 9:27pm
Apparently this one is short on deck now.
