Audio callout requests |
Post Reply ![]() |
Author | |||
paulr ![]() Senior Member ![]() Joined: 24 Jan 2014 Status: Offline Points: 545 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Apr 2016 at 1:59pm |
Per Steve's suggestion, I've started a new thread to discuss possible audio callout expansions. He said "As a potentially interesting aside, we did record about 100 aurals for various things and they are in the code - we just don't make a call to most of them at this time." But in typical AviJake-tease mode he didn't tell us what's already recorded, leaving it to use to make our case for what callouts we'd like to see. I'll start the bidding:
What else? |
1000 Ft, 500 Ft
Minimums Altitude Variation (warn for 200' variation off whatever altitude was being flown when engaged) Optional Gear Check (coincident with 1000 Ft warning) or GUMPS FLTA Disengaged GPS lost Edited by ddgates - 02 Apr 2016 at 2:17pm |
bneub111 ![]() Newbie ![]() Joined: 16 Feb 2015 Status: Offline Points: 33 |
All of the listed call outs here and in the new release thread have good applications for different pilots and situations. How about a place in the setup to turn each one on and off individually? That way we can each pick what we like.
I think I would like: FAF Minimums MAP Another cool thing would be a choice between a chime, CAS message, and/or aural alert for each item. Since this is a wish list, how about a choice of when some alerts happen? For example when do you want a gear/GUMPS reminder - never, 1000', 500', FAF, on impact 😳, if you're lonely all of the above? |
luchetto ![]() Senior Member ![]() Joined: 10 Dec 2015 Location: Switzerland Status: Offline Points: 119 |
I do have a dumb question. I have now the 500ft call out enabled and the FLTA inhibited for landing. I have never heard the 500ft call out is it because of the FLTA inhibition? I don't want to be bothered with terrain warnings all the time but the 500 ft call out on approach would be nice.
Did I get something wrong? |
AUXAIR ![]() Senior Member ![]() ![]() Joined: 01 Jul 2015 Location: KSUA Status: Offline Points: 138 |
I do like most of the listed callouts above:
I would also like to see if we could make the Airspace callouts more intelligent. I would like Class B, C and D callouts, but ONLY if flying at an altitude within 500' of their min/max zones. So if I was at 3500' AGL, I would not get a Class D alert, but I might get an alert for a layer of a Class B or C. I like the way my old Argus turns the airspace depictions red from green if, and only if, you are at an affected altitude. |
David E.
Cessna 182 RG II |
oskrypuch ![]() Senior Member ![]() Joined: 09 Nov 2012 Location: CYFD Status: Offline Points: 3058 |
Yes, for sure the following cardinal locations:
* Orest Edited by oskrypuch - 03 Apr 2016 at 10:45am |
KIM ![]() Groupie ![]() ![]() Joined: 12 Oct 2013 Status: Offline Points: 62 |
For those of us who do not have a GPSS: |
Klaus
Bump.
I've entered this in the candidate database.
100mileperhour ![]() Newbie ![]() ![]() Joined: 23 Jun 2019 Location: Brooklyn, MI Status: Offline Points: 11 |
Doing a Google Search for Aural alerts and not seeing what I was looking for, until this thread! Where is the list aural alerts available? I see this is a almost 4 year old thread. Running 10.2.4.1 firmware.
AviSteve ![]() Admin Group ![]() ![]() Joined: 12 Feb 2018 Location: Melbourne, FL Status: Offline Points: 2153 |
There is no single published list of aurals, but the pilot guide does indicate in several places where an aural alert is generated. If you search the PDF version for "aural", you'll find them. Most have to do with FLTA, but there is also one for airspace and a TOD chime.
I seem to recall Jake saying that there were a numbers of murals baked into the software (and recorded), but not enabled...can't believe it has been that many years ago now.
Thank you AviSteve! That is in fact what I did, was search the user manual. I would suggest a greater list of options for aural alerts for users to chose from in future software updates. I fly a older Bonanza which a some quirks in the fuel management. I have set up IFD, to visually alert me to switch tanks, every 30 minutes. However, when things get busy, and things deviate from the norm, I feel a audible reminder would be a great aid. A gear audible warning wold be another useful aid, that a user could choose to if they wanted. Thanks Michael
Steve, is it still there? |
Klaus
Still there. It's even moved up in the list a little...
Sounds not good! "a little..." in 4 years?
Klaus
cavu ![]() Senior Member ![]() Joined: 17 Apr 2015 Location: KRME Status: Offline Points: 152 |
If you can make a poll on this website, how about list all the aurals you recorded and let us "vote" of which ones would be nice to have? If not, I have polling software setup, you could provide me a list and I could just list the link for people to vote. Jim
Edited by cavu - 25 Apr 2020 at 10:28am |
LOL
Post Reply ![]() |
