  New Posts New Posts RSS Feed - IFD Software Release 10.2.0.0
 Post Reply Post Reply Page  123 15>
 Rating: Topic Rating: 1 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Topic: IFD Software Release 10.2.0.0
    Posted: 01 Apr 2016 at 7:13pm
We are now sufficiently close to completion that it is safe to provide the content of Release 10.2.0.0:
New Features:
1.   1. 1. Added support for multiple options on the IFD-series to include:
a.       WiFi/Bluetooth
b.      FLTA and 500’ Callouts
c.       TAWS
d.      On-board Digital Radar
e.      Video Input/Display
f.        Synthetic Vision
g.       16W VHF Comm Transmit Power
h.      SAR/Special Use
i.         Capstone compliant ADS-B Receivers
2.   .   2. Added support for European VFR Visual Approach, Landing and Area Charts – this is a new chart option in the chart list for those customers who have elected to add that capability to their Jepp subscription.
3.       3. Added support for Digital Radar – a new optional RADAR tab has been added to the MAP page and weather radar overlays are supported on the moving map.
4.       4. Added support for TIS traffic display – adds TIS track lines and TIS related “Traffic Not Available” CAS messages
5.       5. Added support for GDL-88 – added ability to communicate with, and display data from, Garmin GDL-88 devices
6.       6. Added support for GTX-330ES – Adds ability to communicate with, and send ADS-B compliant position data to the GTX-330ES
7.      7.  Added support for Video input and display – a new optional VIDEO tab has been added to the MAP page which displays input from any RS-170 format camera.  The display can support full-color video input and IR camera input and is pinch zoom-able and pan-able.
8.      8.  Added support for TAWS – adds the rest of the TAWS capability to include Premature Descent Alert, Excessive Sink Rate, Negative Climb Rate after Takeoff or Go-Around, TAWS Self Test and associated aurals.   It is likely the TSO approval will be a follow-on approval after 10.2.0.0 release.
9.       9.  Added Synthetic Vision to all IFDs – a new optional SVS tab has been added to the MAP page which displays an “exocentric” view of your airplane against 3D terrain and obstacles along with flight plan information.
10. 10.  Adds support for Search and Rescue and Special Use patterns – provides an option for circular orbits around a point.
11. 11.  Added a new “Direct Distance to Active Waypoint” datablock – this datablock provides a constant snap vector including direct distance to the active waypoint.  This does NOT add a buttonhook type of turn toward the waypoint if not already facing it.
12  12. Added a new “Active Waypoint Direct Info” datablock – Adds a new datablock which displays bearing, distance, time to go to active waypoint using a straight line assumption.
13.  13. Added a new “Designated Waypoint Info” datablock – this is my personal favorite and allows you to designate any waypoint in the system (not just in the flight plan) to be an anchor point and provides bearing, radial, distance, time-to-go data elements.  To change the designated waypoint, just touch on the datablock which pops up a virtual keyboard to type in a new waypoint.  The waypoint selected will survive across power cycles.
14. 14.  Adds Demo mode – this feature adds a means in maintenance mode to put the IFD into Demo mode.  Once in demo mode, a special splash screen pops up at each power up and if you accept it, it puts the IFD into demo mode.  The IFD will “fly” the flight plan entered including any altitude constraints.  This mode is entered if a properly configured USB fob is inserted into the USB port prior to power up.  Great for dealers and even useful for in-airplane ground training.
15. 15.  Added WX-500 Self Test capability – adds a new WX500 self test page to Maintenance mode for debug and troubleshooting purposes
16. 16.  IFD550 Support – Release 10.2.0.0 software fully supports the new IFD550 product which will be released at the same time.  The IFD550 contains an internal Attitude Reference System (a set of TSO’d gyros and accels) that computes and displays a TSO’d attitude indication.  Both Synthetic Vision and a traditional blue/brown ADI depictions are available.  The Synthetic Vision view is an “egocentric” or out-the-window view with 3D traffic, 3D terrain, 3D obstacles, 3D flight plan depiction, Total Velocity Vector (TVV)/Flight Path Marker (FPM) depiction, highlighted airfields and runways, and vertical/lateral deviation indicators.
17. 17.  IFD545 Support – Release 10.2.0.0 software fully supports the new IFD545 product which is the IFD550 without the VHF com/nav capability.
18. 18.  IFD510 Support – Release 10.2.0.0 software fully supports the new IFD510 product which is the IFD540 without the VHF com/nav capability.
19. 19.  IFD410 Support – Release 10.2.0.0 software fully supports the new IFD410 product which is the IFD440 without the VHF com/nav capability.
20. 20.  Adds transponder test capability – a new transponder test page/mode has been added to maintenance mode that tests the transponder output signals and gives great feedback to the installer/tester/troubleshooter.
21. 21.  Adds a port monitor capability – a new page has been added to maintenance mode that allows an installer/troubleshooter to monitor all the traffic on the various data com ports of the IFD.
22. 22.  Adds a Terrain database version ID to the SYS page – just like with Nav, Obstacle and Chart data, we are now displaying the version number/date of the on-board terrain database.
23. 23.  Displays Navaids on FMS INFO tab – adds a new sub-tab to the FMS INFO tab that shows nearby navaids
24.  24. Adds new User ID datablock – this new datablock identifies the current User Profile in use. Especially useful in those multiple owner airplanes or the pilots who want to set up profiles for various phases of flight.
25.  25. Adds Transition Level/Altitude Alert – made additions to the FMS Setup page to allow designation of local area transition level/altitude and has associated CAS messages with them as the transition level/altitude is approached.
26.  26. Adds Sidetone Adjust capability – added a new row on the Volume page to provide a means to adjust the VHF transmission side tone level.
27.  27. Adds other new maintenance mode selections and pages – added several new selection types for RS-232 devices, radar calibration page, stormscope test page, IFD550 attitude sensor calibration page, and others
Improvements:
28.  28  Improved WiFi capability – adds two-way WiFi so data (e.g. flight plans) can be sent from an external device/application to the IFD and added more data in the WiFi stream from the IFD to include ADS-B weather, ADS-B traffic, attitude data from the IFD550/545, user waypoints, stored routes, etc).  This also includes support for the new free IFD100 iPad app which is a fully interactive version of the IFD running on an iPad.  When connected via WiFi to the panel mount IFD, virtually all inputs made on one IFD are reflected on the other.  It's WAY COOL!
29. 29.  Adds 16W VHF Transmit power capability to the IFD 4-series – IFD4-series now has the option for 16W transmit power. Fielded IFD440s can be upgraded from 10W to 16W if desired.
30.  30.  Navigation Database upload speeds dramatically increased – Nav database upload times have been dramatically reduced.  For example, 15MB worldwide nav data used to take 7 minutes to upload and now takes 40 seconds.
31. 31.  Full Bluetooth Keyboard mapping – adds all missing mapping to the Bluetooth keyboards.
32. 32.  Additional ADS-B weather products – adds Winds Aloft, Temps Aloft, and TFRs from the MLB100 datastream for display on the IFD
33. 33.  Ability to turn off individual GPS satellite vehicles – individual satellite vehicle numbers can be manually excluded from the GPS solution in maintenance mode.  This should be especially helpful in the southern hemisphere (e.g. Australia and New Zealand) where WAAS and MSAS satellites can be viewed but may be troublesome.
34. 34.  Enhanced GPS signal lock robustness – a number of additional enhancements were made to the GPS lock algorithms.
35. 35.  Allow multiple outputs of the same data stream – previously, you could only have one instance of a RS-232 data type in Maintenance Mode and now you can have up to 6 instances of the same type.  For example, you can now set “Aviation” on all six serial ports if you want.
36. 36.  Configuration Save Improvements – this should help out those customers who use the Windows simulator and configure the IFD as they want and try to save those settings to a USB fob for importing into an actual IFD.  Those settings were not being fully implemented on the actual IFD until now.
37. 37.  Add aural alert to ADS-B traffic TAs – An aural “bing” now accompanies ADS-B sourced traffic TAs.
38. 38.  Improved VOR nav sensitivity – the overall VOR sensitivity was improved which greatly improves Morse Code decode times and accuracy.
39. 39.  Improved enroute transitions - When inserting a SID into the flight plan, the system will generally present only a dropdown containing enroute transitions. When the user selects the transition, a SID is inserted with a runway transition corresponding to the selected runway. However, if there is no selected runway, then no runway transition is inserted. This has led to some users wondering why their SID is "missing legs".  That has been addressed in 10.2.
40. 40.  Added WiFi and Bluetooth logo icons to the top datablock strip – the added logos will be a clear indication which capability has been enabled on that IFD
41. 41.  Moved the WiFi/BT accept dialog box up to the startup sequence – moves that dialog box up to the startup sequence if the IFD has WiFi or Bluetooth enabled and at least one of them configured in User Options to be On.
42. 42.  Depicted GPS signal strength – improves the visual depiction of GPS satellite signal-to-noise ratio bars on the GPS status page
43. 43.  Enhanced Guard Freq swapping behavior – When pressing and holding the Swap key to push 121.5 into the active com freq, the system will now automatically push the previous active freq into the standby slot.
44. 44.  VLOC Yellow on ILS Approach – there were some ILS approaches that were coded differently in the nav database and did not toggle the VLOC nav source indicator to green when they should have.  That has been rectified in this release.
45. 45.  Offer more possibilities when entering a waypoint – instead of limiting dropdown waypoint choices to previously determined most logical choices, all choices with the identifier are now possible.
46. 46.  Improved thumbnail dwell time - adds a dwell time requirement to effect change on the traffic and transponder thumbnails.  This fixes an issue where scrolling the datablocks column could adversely/unintentionally change the traffic or transponder state
47. 47.  Improved Published Holds – there were some subtle uses of published holds that we did not know about operationally.  This change allows selection of the type of hold to be used when there are multiple published holds on the same database waypoint.
48. 48.  Runway length in meters - When meters selected as units in User Options distance units field, the runway length information on the INFO tab will be displayed in meters. Also affects map pop up info boxes and Map Setup page filtering by runway length.
49. 49.  ADS-B traffic symbols – adds the directional indication symbol to ADS-B sourced traffic blips
50. 50.  Cyclic scroll on waypoint lat/lon entry - When entering in lat lon coordinates, instead of preventing a rollover from 0 to 9 as pre-10.2 behaved, now you can twist the knob to go around the horn.
51. 51.  Timer label changes – a few cosmetic changes to titles of timers.  “Departure Timer” is now “Event Times” and start options have been wordsmithed.
52. 52.  Title change of User ID datablock – changes the title of the datablock from “User ID” to “User Profile”.
53.  53. Jet/Victor Airways visibility on map – changed the altitudes at which Jet Airways and Victor Airways are suppressed from view on the map.
54. 54.  Removed floating “TRK” - In pre-10.2 systems, if you turned off the digital heading box on the Map, we left a floating “TRK” indication.  That is now removed if digital heading/track is removed too.
55. 55.   Map tab hiding info on Charts page – moves the page alignment as required so that the MAP page tabs do not obscure Chart data.
56. 56.  Enhanced virtual keyboard ops during edits - removes a behavior where the virtual keyboard would be removed if you used the space key during edits to the User Profile name.
57. 57.  Improved cursor behavior on Chart list page – prevents the cursor from moving beyond your field of view (below the visible page) when on the Chart list page.
58. 58.  Removes invalid temps from Mx Mode display page – removes some unused or invalid temps on the I/O card sub-page in Mx mode.
59.  59. Improved GPS status flagging – no longer flags GPS position as “bad” when the UTC Invalid flag is set.
60. 60.  Changed default state of maintenance mode updates page - changes the default of all FOB files being selected for upload to no files selected in an attempt to reduce unintended SW/database or updates loading.
61. 61.  KFC225 Nav Arming in Dual IFDs – improves the clarity of which IFD arms the autopilot NAV mode in dual IFD-KFC225 equipped aircraft.
Issues Remedied
62. 62.   Restore missing datablock in top datablock strip – restores the missing Crosstrack Deviation datablock option to the top datablock strip after it had been inadvertently removed a few releases ago.
63. 63.  Fixes Datalink no coverage cross hatching indications – we had some cases where big/gigantic no-coverage cross hatching indications from ADS-B weather were displayed.
64. 64.  Fixed times in G500 and GMX200 - There were some conditions where the times displayed on the G500 and GMX200 were off by an hour due to a bug in our interpretation of the data messages.  That’s now resolved.
65. 65.   Fixed GMX200 Reboot issue – remedied an issue that would cause the GMX200 to reboot after its disclaimer page was acknowledged.
66. 66.  Fixed improper use of pressure altitude on GPS Status Page – eliminates the use of pressure altitude on the GPS Status page for the altitude field and in the Aviation 232 output stream.  It’s GPS Altitude or nothing now.
67.  67. G500 ILS Autoslew course issued resolved – remedied an issue in which the ILS course was not always properly autoslewing in a G500/600.
68. 68.  Altitude Constraint Removal issue resolved – remedied an issue in which the inserted altitude constraint would get removed when inserting an airway after a leg.
69.  69. Remedied and issue in the way arc legs were drawn on Garmin displays - resolved the issue where on MX20/GMX200/G500, Arc legs are not able to be drawn greater than 255 degrees. Most DME Arcs are significantly less than that but it has been found that the Nav database does contain some arcs that are greater than 255 degrees (ex. SASJ OSEBO 4A Departure - GESPA transition)
70.  70. VR leg altitude constraint radial display fix – remedied an issue where the radial on an altitude constraint VR leg would not display 3 digits if less than 100 degrees.
71. 71.  Fixed Next Leg CAS issue – the “Next Leg” CAS message was supposed to be a Delete on Ack message but that was not implemented correctly in Release 10.1.1.0.
72. 72.   Remedied an issue in datablock location display – remedied an issue that caused discrete jumping of display location in datablocks when using User IDs 2-5.
73. 73.   Fixed inappropriate dismissal of virtual keyboard – some of the AUX – Setup pages would get keyboards in places and times that they shouldn’t and this is now fixed.
74. 74.  Fixed AM/PM error in ETA calculation –remedied an issue that typically produced an error in ETA time label (AM was PM and PM was AM).
Edited by AviJake - 02 Apr 2016 at 3:07pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 7:16pm
And now for the wave of questions....
But first a few pre-emptive statements:
1.  We're in final company testing of this release but it's not done until it's done.
2.  We'll be done as soon as the FAA signs off on the release
3.  The release is $0.
4.  There are some paid options included in the release that cost more than $0.
5.  It's a ridiculously cool release.
6.  We will have it on display at Sun-n-Fun including the IFD100 and IFD550.
7.  I expect to post a draft Pilot Guide for download and review within a week of the show ending.
8.  No Orest, the IFD100 is not (yet) available in Android.
Edited by AviJake - 01 Apr 2016 at 7:28pm
TomG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 7:43pm
Sound's Great!
Can't wait to see all of you next week!
Tom Goodwin
V35 B W/
IFD 540
AXP340
MLB-100
Tom G
ddgates View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 7:56pm
Wow!
Is there an upgrade pathway from the 540 to the 550?
It sounds like to some degree the IFD100 makes the outside vendor apps nearly superfluous.
Overall, way more than one would have hoped to realize.
Congrats, Steve.
Edited by ddgates - 01 Apr 2016 at 8:04pm
bellanca1730a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bellanca1730a Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 8:59pm
Wow! Just wow! Congrats, Steve!
Sean Andrews
Bellanca Super Viking
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:02pm
1)  Yes, that is a biggie, is a 540 factory upgradeable to a 550, or is it a completely different box inside?
2)  Can a stock 540 (or 440) use an external ADHARS source, like an ASPEN or G500 to display the egocentric SV and/or AI?
There is a lot of cool stuff! Also, very interesting about the *armin stuff cross connectivity, that may really help a lot of folks make up their minds.
But, no Boeing Banana. I even checked twice!
Maybe 10.3!
Edited by oskrypuch - 01 Apr 2016 at 10:05pm
TomG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:14pm
So how does IFD 550 connect to the new version of the PFD4000, and how much??
Tom G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:19pm
Wow, that's AWESOME!!  I just saw the email from Avidyne and had to jump o nthe forum to see what was happening here.  I'll see you at SnF.
74 features.  Wow.
Was one of them the banana?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:20pm
Really good questions...
teeth6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:41pm
Absolutely amazing.  Much more than anyone could have hoped for.  Take THAT *armin!!
I would have fully expected that some features would be more than $0 to activate. It not cheap to engineer these enhancements and get them approved.  Can you say which will incur a cost and the approximate amount?
310pilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 310pilot Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 9:47pm
I am soooooooo glad I put an IFD in my airplane. Can't wait to see all the cool stuff this release offers in action. Great job!!
Harmik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harmik Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:04pm
interested to know about the upgrade also.
Harmik
Edited by Harmik - 01 Apr 2016 at 10:06pm
Harmik
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:26pm
You can make assumptions...
TAWS is an option.
Radar is an option.
Probably video is an upcharge.
BUT what is important is what they have said is NOT an upcharge.
  • 10.2
  • Syn Vis
  • IFD100
  • WiFi/BT
  • Full keyboard function
I am sure they understand their business plan.
I personally  am rooting for them.
Edited by ddgates - 01 Apr 2016 at 10:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:27pm
I'm glad I did dual units; with the increased functionality, will be able to keep both screens busy!
safari View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote safari Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 10:36pm
Amazing
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:01pm
We've always believed we had the superior engineered boxes with the best user interface.  We had some mis-steps coming out the gate with the IFDs and are still working through a few pesky issues but we're finally able to start rolling out some of the capability we planned for from the very beginning.   And we're not done yet.
Now for a few of the questions so far:
Can you upgrade your existing IFD540 for a new IFD550?   Yes but of course that involves buying an IFD550.  I know that's not what you meant so the real answer is "No", the existing 540 can not be upgraded to a 550.
What's different about the 550?  Is it a whole new set of guts?    No, not really.   We developed and certified the 540 from day one with the ARS (Attitude Reference System) in there.  All of our hardware and environmental quals from 2+ years ago had the ARS in there on purpose so we didn't have to requal now.   So that sums up to be the 550 is a 540 with the open cavity in the bottom now populated with an ARS and a new bezel that has the 4th Page Function key ("SVS").     The 550 is still plug & play with a 530 to the same extent a 540 is.  550 is the exact same form factor and uses the exact same tray and wiring.
What features have an upcharge associated with them?    The items listed at the top of this thread under item #1 are the only ones that have upcharges or unlock fees associated with them.    Now there are all kinds of asterisks even with that statement.    Everybody who has a 540 or 440 already got WiFi, Bluetooth, FLTA and 500' call outs.  There is no new charge for that at all.     In fact, as a quick side bar on that, you may have noticed that the price for 440s seems to have decreased from what the early purchasers paid for.  That is technically true but the base price of the 440 does not include WiFi/Bluetooth/FLTA/500.  When you add those options in, you're back up to the original price of the 440.
How much are the various up charges?   Sorry but I need to consult with Sales on that one.   I made a note to myself to be prepared with those numbers when I made the original post on this thread but I forgot to do that.   We should have those numbers by Tues, if not earlier.  I think they are even being distributed to dealers and Avidyne Insiders tonight.   Apologies for dodging that question.
Where the heck is the Boeing Banana?    It's on the candidate database but didn't make the cut for 10.2.  Clearly we're aware of the interest in that feature and agree that it's very cool and useful.   Someday.....
Can a 540 or 440 take in ADAHRS data from an external source like Aspen or G500 and do something with it?   No, I'm afraid not.
What's the interconnect story with the PFD4000?   Well technically the PFD4000 is still in the ether and doesn't exist as a product yet.  However, when it does become a shippable product, it will clearly be able to have a full interface with the IFD series of units.   Note that we are asserting the IFD550 is a "non-required secondary attitude indicator" meaning the STC we are in the middle of right now does not allow for the IFD550 to be one of the required attitude indications in your airplane whereas the PFD4000 would be.    Now you can (and should) let your imaginations run wild here with the possibilities.  The IFD550/545 is a fully TSO'd attitude sensor/indicator and uses all the same  technologies as our other primary systems do.   Ponder that for a while.....
squeege View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote squeege Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:13pm
Come on, this is a huge April Fools joke, isn't it?
Louise
AUXAIR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:14pm
What a terrific set of features!
I, too, am glad of my choice of Avidyne 540/440/340 and their great product support.
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth6 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:16pm
I'm sure all will become clear soon enough but you did explain how the upcharge for WiFi, BT and FLTA is being handled with new units.  For those already with WiFI and BT, do you still anticipate a charge to unlock the full features of the keyboard and WiFi?    I thought the SV would carry a charge and it is listed under item #1 above but the email sent out by Avidyne earlier today states, "Synthetic Vision at no additional charge."   Which is correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:20pm
Wait until you see the demo of the IFD440 connected to the IFD100 on an iPad Pro via WiFi at Sun-n-Fun. It's just sick.
brou0040 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:24pm
IFD100 will work instead of IFD340 ;)  Very glad to see that come true.  I'm also an Android user and will be waiting patiently.
With all the surprises with the IFD line, is there any chance for a dual band in MLB?  The ADS-B upgrades are making an IFD/ADSB solution more tempting.
Edited by brou0040 - 01 Apr 2016 at 11:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:25pm
It's a little complicated and I'm typing on a phone so this won't be the complete answer but,
There is no up charge for the full WiFi functionality.
WiFi/BT comes standard on all 5-series units.
There is no up charge for full keyboard functionality.
Believe it or not, at least for now, the SVS option on all units is $0 (this is NOT an April Fools joke). This is the new tab on Map page that is the exocentric "in trail" view. It's really neat.
MysticCobra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:30pm
(Looking closely to see if there's an "April Fools!" hidden in fine print anywhere....)  ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:54pm
Going back 1.5 years, will the IFD550 ARS allow users to add a DFC90 without an Aspen?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AUXAIR Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2016 at 11:59pm
Steve -
One of the new features that interests me most is support for SAR.
"10. Adds support for Search and Rescue and Special Use patterns – provides an option for circular orbits around a point."
Can you comment on whether this feature extends to the ability to set up and use Sector searches, or the ability to define A Commence Search Point and use it as the basis for setting up a set of parallel tracks at fixed offsets?
Thank you,
Edited by AUXAIR - 02 Apr 2016 at 7:12am
David E.
Cessna 182 RG II
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 12:31am
<span style="line-height: 1.4;">Now you can (and should) let your imaginations run wild here with the possibilities.  The IFD550/545 is a fully TSO'd attitude sensor/indicator and uses all the same  technologies as our other primary systems do.   Ponder that for a while.....</span>
Couldn't the 550 BE the autopilot (of course with srrvos) sort of like the G3X?
DH82FLYER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DH82FLYER Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 12:45am
Is there a charge for the non-certified TAWS functionality?
mfb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mfb Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 1:13am
When will a 10.2.0.0 version of the PC and/or iPad simulator be available?
chflyer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 5:00am
Cool!!
A very good mix and choices of no-charge functionality increase for existing installations vs add-on purchase options. Excellent work to retain and enhance the value for the current customer base, especially those of us who have held in there with Avidyne over the last few years on this journey.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chflyer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 5:53am
3.
        A couple question related to this point in the list ...
        1) These VFR charts contain many VRP's (Visual Reporting Points, nearly 700 in Italy alone), which up to now have not been in the Jepp navdata and therefore couldn't be added to flight plans. Does this mean that the Jepp navdata will also now include them? I expect that the answer here is NO, but hoping for a YES.
        2) Are these charts supported and can they be loaded into the IFD concurrently with the existing, IFR charts? I expect that the answer here is YES.
Edited by chflyer - 02 Apr 2016 at 5:56am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidBunin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:19am
I noticed that the name/title of this forum room changed.
PeterC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:36am
Steve, that is an amazing list! Congratulations for providing such a great release while still providng excellent support to your installed users. Now you really make us think -"What could they do next?" You just moved that bar to a whole new level. I can't wait to see it all on Tuesday.
Peter - 1977 Cardinal RG C-FJPC - IFD550/540/240/322/605A/Skytrax100, Aspen MAX 2000, Trio A/P
AviSimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:55am
No, not today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:57am
Working on that now. Should have it soon via the website.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 7:58am
I changed it at 3pm yesterday but no one noticed...
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:27am
Originally posted by AUXAIR AUXAIR wrote:
Steve -
Thank you,
No, not yet.  The SAR package is limited in Release 10.2 to only have circular orbits.   The rest of the more traditional SAR pattern options are still on the post 10.2 to-do list.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:29am
We like your thinking but we're not there yet.  There is no engineering reason why that can't be the case but we have a lot more work in front of us to accomplish something like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:30am
Originally posted by DH82FLYER DH82FLYER wrote:
The short answer is "I'm not sure yet."
It is an active internal debate.  Stay tuned.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:32am
3.
1.  I don't think so but let me double check with Jepp.
2.  Yes.
Freff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freff Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:43am
What is the difference between FLTA and TAWS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:49am
FLTA is "Forward Looking Terrain Alerting".  It is a subset of full TAWS functionality.  (TAWS being Terrain Alerting Warning System).
Full TAWS-B has several elements:
1.  FLTA
2.  500' Call outs
3.  Excessive Descent Rate Alerts
4.  Premature Descent Alert
5.  Negative Climb Rate After Takeoff or Go-Around
#1 and #2 have been in the IFDs for some time.  Release 10.2 adds #3, 4, 5.
#3,4, 5 are specified in the guidance that covers TAWS systems in a very specific manner and are designed to address other real-life corner conditions that resulted in real CFIT accidents.
The draft Pilot Guide that I will post in the next week or so has explicit descriptions of those new areas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brou0040 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:57am
Since there seems to be a bunch of questions about upgrading to the 550, perhaps you could mull this over with sales/management.
For a customer that upgrade to the 550, would you be willing to "refurbish" the current units, which may be no more than sending the units back for all of the latest hardware updates, inspection, and certification?  I don't see this being much more than your current customer service work, but having some sort of "certified pre-owned" policy may help the existing 540s sell making it easier for current customers to make the upgrade.  Also, would you be willing to reset the old 540 warranty for it's new owner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 8:59am
Okay, I'll huddle with the appropriate players on Monday to discuss your suggestion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MysticCobra Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 9:26am
I am definitely in the camp of "very interested in upgrading to the 550 if the delta cost is reasonable".  I can't imagine I'm the only one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 9:55am
Understood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 9:59am
I continue to be beyond impressed. I see a path with what you are doing.
Jake/Simpson:
1. Not explicitly mentioned. Does 10.2 support flight plan save with altitude restrictions?
2. Is there an intermediate between full TAWS and FLTA? I'm thinking of more audio call outs.
3. Are you going to develop "suggestions" or a "super users" forum? Seems that such could be useful in the setting of a large panorama of options.
4. What about suggested optimal configurations for dual 540s or 540/440 combinations?
5. Does 10.2 support MLB data streaming via wifi?
6. Is IFD100 ok on Mimi or does it require iPad Pro?
I could go on...and on...but can't make it to Florida- so those who go from this forum need to be reporters...
Edited by ddgates - 02 Apr 2016 at 10:02am
Post Options Post Options   Thanks (1) Thanks(1)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 10:04am
Reference David's 6 questions:
1.  Yes, my bad for not including it in the list but I do have an explicit note in the new Pilot Guide about that.
2.  Not as part of 10.2.  What audio call outs do you have in mind?  As a potentially interesting aside, we did record about 100 aurals for various things and they are in the code - we just don't make a call to most of them at this time.
3.  Dunno.  I'll let Simpson handle that one.  (You're welcome Simpson)
4.  Yikes.  An impressive exercise in combinatorics.   Might be doable but I'm leary based on the myriad of potential configurations any given customer may have.
5.  Sort of.   10.2 enables the streaming out via WiFi of ADS-B traffic and weather.  So, MLB100 supplied traffic and weather, can now pour out of the IFD over WiFi and be caught and done something with by the various app providers who have, or are working on, compatible apps.  The IFD100 will take and display that data on the map and traffic thumbnail.
6.  Yes, IFD100 works on the Mini - that's what I use in my cockpit.
Edited by AviJake - 02 Apr 2016 at 10:07am
Post Options Post Options   Thanks (1) Thanks(1)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 10:20am
Thanks, Jake.
I spend all too much time on the aluminum tube and hear their call outs: 2500, 1000, 500, 100, and minimums.
The IFD approaching this would kind of be a poor man's radio alt.
Aspen blew it when they shortcut their alerting with the Sonalert rather than audio. The IFD could do that (and yeah, I'd pay for it) - think about alt alerting. Should be doable with the functionality you already have. Could save some IFR altitude busts.
If we are going big:
Ultimate suggestion - BUY GENESYS!! FREE the DFC-90.
(Only partially tongue in cheek)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddgates Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 10:30am
Also - how will two boxes handle traffic alerting from TAS on one box and MLB on the other? Audio plus Bing? Or does one or the other get primacy?
Slatye View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slatye Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2016 at 10:34am
Wow, that's a lot of updates! I'm guessing that there's not going to be an "IFD450", like a smaller IFD550?
Any chance of a list of which radar units are supported?
This page was generated in 0.238 seconds.
