  New Posts New Posts RSS Feed - constant syncing
constant syncing
psimpson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psimpson Quote  Post ReplyReply Direct Link To This Post Topic: constant syncing
    Posted: 27 Oct 2015 at 10:59pm
https://www.youtube.com/watch?v=C4j2c3oOvmc
Hope you can see this clip but I can't load a flight plan unless one of the 440's is powered off.  If this doesn't work use the link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote LANCE Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2015 at 11:27pm
I would check in the installation manual on pages 51, 82, 114 & 191. There is info re: the settings dual installations and cross sync.
Post Options Post Options   Thanks (0) Thanks(0)   Quote psimpson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 10:06am
They are syncing as in you put a plan or approach in and it is in the other one.  They worked for 2 months before this started.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 10:50am
How many flight plans do you have stored?
Post Options Post Options   Thanks (0) Thanks(0)   Quote psimpson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 12:45pm
maybe 5 or 6, is that too many?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviSimpson Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2015 at 2:49pm
It shouldn't be. Anyway you can get your datalogs over to techsupp(at)avidyne.com. I imagine they would want to see what's going on here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote psimpson Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2015 at 8:52pm
I got a replacement unit and everything is fine now.  TJ helped me get it going.
This page was generated in 0.191 seconds.
