  New Posts New Posts RSS Feed - IFD comm with JPI EDM 960
310pilot View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 310pilot Quote  Post ReplyReply Direct Link To This Post Topic: IFD comm with JPI EDM 960
    Posted: 25 Jul 2015 at 7:47pm
Not sure if anyone else out there is running a EDM 960 along with the IFD 540. Communication is both ways, the EDM is supposed to send Fuel data to the IFD and the IFD is supposed to send GPS data to the IFD. I have found that this communication is intermittent. Sometimes the data is displayed on both units, sometimes one unit sometimes there is no communication at all and neither the IFD nor the EDM displays the info it is supposed to receive from the other unit.
By chance is anyone else running an EDM system and can provide feedback of what they are experiencing when it comes to communication between these two devices??
rolfe_tessem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rolfe_tessem Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 8:54pm
Okay, I'm interested. What does the EDM do with the GPS data?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 310pilot Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 8:58pm
It displays GPS data like ground speed and used that and distance remaining data to calculate and display fuel to destination , reserves at destination etc.
Craig767 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig767 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 9:53pm
I have that set up. Both 540 & 960 fuel data seems to work most of the time. Only issue is 960 looses GPS data very occasional, so don't know if 540 problem or loose connection which seems to happen with the 960.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 310pilot Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2015 at 9:56pm
Thanks Craig. That is mostly what I had been experiencing until lately. Intermittent outages on the EDM. Last couple flights the EDM hasn't been able to tell me fuel remaining at destination.
billan07 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote billan07 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2015 at 9:57pm
I have an EDM 730 and have no communication between it and my 540s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oskrypuch Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2015 at 10:23pm
Well, no systemic issue -- EDM 730/830s work just fine with the 540. Most likely reason is that the parameters are not set up correctly.
I have the GPS-C setting on the EDM set to "7" = 430 "to destination".
The EDM is connected to 232 channel #1 on the 540, and that is set to: I = Shadin-fadec; O = Aviation on page 2/10.
If you are not comfortable checking those, get back to your shop. That should have been proven working before the plane was handed over.
Edited by oskrypuch - 05 Aug 2015 at 10:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 9:54am
Is this still the case for you?   We definitely work with the EDM units so I suspect it was a configuration issue with your airplane.
Post Options Post Options   Thanks (0) Thanks(0)   Quote billan07 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2015 at 2:12pm
Yes this is.  My avionics shop has been trying to resolve this issue with your tech support but has been getting no response to their emails. I sent Orest's response to my earlier post to them and am a going to follow up on Monday to see if that will solve the issue.
