  New Posts New Posts RSS Feed - Warning Obstacle
Warning Obstacle
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Topic: Warning Obstacle
    Posted: 28 Jun 2015 at 2:58pm
I realise that warnings for obstacles .. for example .. are very useful. However .. sometimes one just wants to circle around a point below 1000ft .. or better .. when approaching my home airport .. we are often required to come in at 1000ft .. The warning will go off quiet often.
I presume you can switch of (permanently?) .. however .. one day that maybe a warning you really did want to hear. .. So what is the sensible setting or solution?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 4:47pm
Just touch the CAS message or press the adjacent ENTR button on the bezel to shut it off for that episode.
wsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wsh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 6:04pm
Done that (several times)
10 sec it reappears
Post Options Post Options   Thanks (0) Thanks(0)   Quote AviJake Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 6:14pm
You'll have to send the logs.  Once you ack an alert for a given obstacle or ground proximity, then it will not alert again.   Any new alert will be a new obstacle/ground or you reset the alert by turning away then back at the threat.
Send us the logs and we can verify ops.
